Tools you need!!!
Old Jan 9, 2009 | 08:16 PM
outlawzsouljah's Avatar
Default Tools you need!!!
Hey ppl.. I'm just wondering what kind of tools you need to change a stock front end Integra type R to a JDM Front end?.. anyone give me a list of tools that I'll need.. thank you!!
Old Jan 9, 2009 | 08:33 PM
iwanttokillgod's Avatar
Default Re: Tools you need!!!
basic tools and a saw, if you want it done right a welder
Old Jan 9, 2009 | 08:39 PM
brisauce's Avatar
oh goodness.
Old Jan 14, 2009 | 09:37 AM
SuckMyDOHC's Avatar
a brain, socket set with ratchet, sawsall, drill, and welder.
Old Jan 14, 2009 | 09:54 AM
dre_6544's Avatar
http://www.angelfire.com/sc3/nguyen/JDMFEC.htm
Here is a good link to give you a good idea of tools and what you have to do. Hope it helps. That's what i used to do my front end.
Old Jan 14, 2009 | 10:09 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
wow... bolting/screwing on the radiator support is such a dumb@$$ idea. Say bye-bye to your front-end rigidity. Why? Parts can rotate around bolted connections, while welded connections cannot move.
Old Jan 14, 2009 | 10:30 AM
YellowKahuna's Avatar
Did you get into some kind of accident? If not I would leave the R with the USDM front.
Only reason I have the JDM front is because of an accident I had. I got hit in the right front and there went my R's value, F it went JDM front, Oh well. If I didn't get into an accident I would still have my USDM front on the car.
Old Jan 14, 2009 | 05:51 PM
Tekkaboy's Avatar
http://www.team-integra.net/forum/di...TopicID=193282
Old Jan 14, 2009 | 10:48 PM
Tight R's Avatar
10mm socket, 12mm socket, extension, rachet, drill, drill bit, welder, grinder, rotary cut off wheel,
Old Jan 16, 2009 | 02:36 PM
thanks guys.. No I didn't get into an accident just wanan change my front end to JDM... I don't like it Stock...
Old Jan 17, 2009 | 11:20 AM
SuckMyDOHC's Avatar
but the JDM front end is stock...
Old Jan 17, 2009 | 12:30 PM
grjp1988's Avatar
Why did you buy the car then? should of baught a jdm front car...? go ruin a clean type r
Old Jan 17, 2009 | 03:19 PM
CWTegRNo.160's Avatar
Isnt there a way to modify the usdm bumper support to fit the JDM bumper? I would rather go that route. Is it true that there is a rule that doesn't allow jdm front teg owner to autox because the weak bumper support? Sounds like a SHOWKAA to me.
Old Jan 18, 2009 | 01:34 PM
Bone head move if you ask me
Old Jan 18, 2009 | 02:14 PM
dropkneeyoungin's Avatar
like yellowkahuna, i got into a front end accident with my usdm front....fkn thing WAS perfect minus a small scratch till i rear-ended a kia doing 4 mph....so im too saving up for a jdm front because my front end never fully got straightened out after the accident....pics if anyone wants to see wut i mean...
Old Jan 24, 2009 | 10:31 PM
EL TYPE R's Avatar
A size 10 socket and wrench, all a Honda needs. hahahahahaha
smoked08
Apr 4, 2011 09:48 AM
gospeedgo1
Jan 11, 2007 10:45 AM
shrums-EG6
Feb 20, 2006 07:04 PM
TypeRPinoY
Jan 9, 2003 11:04 AM
98ITR#0020
Mar 12, 2002 10:18 AM
