1996 Honda Accord Timing Belt Seals
Old Jan 9, 2009 | 03:57 PM
Cristo88's Avatar
Icon6 1996 Honda Accord Timing Belt Seals
When getting an oil change, i had my timing belt inspected. The timing belt cover was taken out and the engine was lifted up with a wooden block. After this, the timing belt seals are now leaking and the power steering pump is leaking. Are these leaks related to doing all that??? Or is it coincidence, because it wasn't leaking before. Help!
Old Jan 9, 2009 | 04:53 PM
dtapia's Avatar
Default Re: 1996 Honda Accord Timing Belt Seals
NO they were leaking before you just had not paid attention until some one brought it to your attention.
Old Jan 9, 2009 | 05:45 PM
Cristo88's Avatar
actually we both saw that it wasn't leaking before. and my carport was clean before. and now there are big spots everywhere. weird!
Old Jan 9, 2009 | 06:38 PM
P_Adams's Avatar
Sorry, but I believe it to be coincidental. Taking the cover(s) off to inspect the belt would have no effect on the shaft seals.
They would have been (most likely) worn already.
Now, if you were asking aboot a crushed oil pan THEN I could point to the "Lift the engine with a block' proceedure.
P
Old Jan 9, 2009 | 06:53 PM
Cristo88's Avatar
Thanks!! .... can you guys go to my Rocker Arms Seals post. I also have a question about those leaking.
B18C5-EH2
Aug 7, 2015 06:41 PM
jnb0111
Jun 8, 2011 07:36 AM
pushintealhondas
Feb 16, 2008 07:29 AM
shepworldwide
Acura TL, RL & ZDX
Aug 15, 2006 07:37 AM
