URGENT!!!! Prop Valve Leaking!
I have a 94 EX. I'm stuck 45 miles away from and my car is barely going into gear. STock brake system. There is fluid coming from some lilttle whole on the prop valve!!!
HELP URGENTLY, I can't even undo the flares because they just won't budge even with a flare wrench and tight space with intake manifold in the way!!!!!
What do you want us to help with? Call a tow truck and get it home to work on it.
Your car not going into gear and your prop valve are 2 different problems.
Well I physically see the fluid coming on of some hole underneath one of the brake flanges on the prop valve. I wonder if my clutch master cylinder is going as well. Wow everything just take a poop on me at once. Oh yea I was in the process of registering for school, I have NO MONEY!!! I finally made it home, but I have no ride back to school, but I'll get there in time for monday.
ok lemme clear this up. someone take a look at their prop valve from civic ex w/o abs. I have a 94. Looking from the intake(pass) side, there is a hole underneath like one of the flanges going into the prop valve. My fluid is leaking out from there. has anyone experience this?? Is there a plug that came out (maybe a ball bearing springload), or is that a sign of the prop gone bad? I had someone pump the brake while i put my finger up to it and i could feel like some suction and pushing of air. I dont know if thats like a vent hole, but that's where its leaking. I'll try to get pic and a vid but its dark out, but i'll try.
mingbling96
Dec 20, 2004 10:19 PM
BI8B
Sep 16, 2003 08:21 PM
