still no spark
Old Jan 9, 2009 | 01:14 PM
mikehawk's Avatar
Default still no spark
wasnt getting spark from the coil .. changed guts with another dizzy still no spark from the coil what else can I check? or should I try and replace? need some fast answers so I can get back on the road and go to work before I get fired lol.. thanks guys
Old Jan 9, 2009 | 01:35 PM
intense4thgen's Avatar
Default Re: still no spark
you have power at the coil? i recomend you find a "no spark" troubleshooting write up
Old Jan 9, 2009 | 01:42 PM
bmxmacdaddy's Avatar
ignition module? Or is that what you meant by coil?
Old Jan 9, 2009 | 01:43 PM
lol check your computer... Make sure its still there
Old Jan 9, 2009 | 01:52 PM
mikehawk's Avatar
mikehawk's Avatar
no spark at the coil
Old Jan 9, 2009 | 01:53 PM
mikehawk's Avatar
so .. check my ECU as well? what do you mean by ignition module ?
Old Jan 9, 2009 | 03:54 PM
nub's Avatar
nub
Tested the ignitor?
Old Jan 9, 2009 | 04:29 PM
mikehawk's Avatar
no power to coil
Old Jan 9, 2009 | 06:22 PM
nub's Avatar
nub
ck fuses
Old Jan 9, 2009 | 08:20 PM
Former User's Avatar
Originally Posted by mikehawk
no power to coil
The ignition key must be turned to ON(II) to check for power at the coil. As mentioned, if there's no power in this case, check whether fuse 39 or 41 under the hood is blown. If the fuses are fine, then check the ignition switch and whether the Blk/Yel wire running between the coil and ignition switch is damaged.
Old Jan 9, 2009 | 10:20 PM
if im not mistaken the power for the dizzy is triggered by the main relay same as the injectors.
i know for sure it is the 2 wire plug at the firewall drivers side by the headlight box and its blk/yellow wire id check for power there
Old Jan 10, 2009 | 02:28 AM
No, the main relay does not control power to the dizzy.
Old Jan 10, 2009 | 10:02 AM
mikehawk's Avatar
thanks i will check those when I can. the fuel pump cuts on and stuff still too but i will check the ignition switch .. and going to swap in a known workng ecu to see if maybe that has any affect.
Old Jan 10, 2009 | 01:44 PM
LSej1's Avatar
I higly recomend checking all your fuses under your dash VERY well...I had this problem and replaced the dizzy and every part in it and check my fuses three times. Still no spark. I went back and checked the fuses one last time and there was a tiny split in one of them. I forget what fuse it was but once i replaced it the car fired right up. Check them closely
RIFC75
Feb 22, 2016 01:11 PM
x19trix72x
Sep 30, 2008 04:43 PM
dapaur
Nov 1, 2007 06:40 PM
JDM_EK4_Coupe
Apr 15, 2007 08:00 PM
ChilBlu92
Dec 28, 2006 06:35 PM
