Straight b20b w/ GSR tranny
Old Aug 5, 2002 | 07:20 PM
TORQUE MONSTER's Avatar
Default Straight b20b w/ GSR tranny
anyone running this setup?? how fast in 1/4 mile and can you beat a hatch with b18c1??
do you find the GSR gearing a little too short?? feed back please..
Old Aug 5, 2002 | 10:17 PM
POLLO's Avatar
Default Re: Straight b20b w/ GSR tranny (oelam@hotmail.com)
With a stock b20b and a GSR tranny and an LS ecu a compadre of mines is running around 13.8 @ XXX can't remember the trap speed.
Old Aug 6, 2002 | 06:05 AM
jdm4life's Avatar
Default Re: Straight b20b w/ GSR tranny (POLLO)
I have the same setup right now.....GS-R Tranny mated to a JDM B20B and running to a P75 (LS ECU). It is pretty short but I think it is a much better setup then using a LS tranny. If i didn't have it i wouldn't be able to pull on GS-R's and Si's. So the tranny does help, it is short but it brings out the engine's power better. I ran only mid 14's, however my clutch was slipping down the track and I was on stock 13 inch VX wheels, stock piping and muffler too ...Hey now, I just got the car back and haven't been able to finish it yet. Think I can pull high 13's and a 14 flat if i fix everything? I have on order (should be here soon but not soon enough) Carsound 2.5 inch in/out highflow cat and Magnaflow 2.5 inch in/out SS oval Muffler, and a brand new set of OEM tegra LS Wires/Plugs From the Acura Dealer.
Needing Clutchmaster clutch (Stage 3), ITR AEM CAI, Performance Brake Pads & Rotors (Stock VX Hatch brakes won't stop ), New Tire/Wheel Combo (Stock VX Wheels Won't Hook Up )
In Time In Time
[Modified by jdm4life, 7:08 AM 8/6/2002]
[Modified by jdm4life, 7:16 AM 8/6/2002]
Old Aug 6, 2002 | 11:37 AM
xxplosif1's Avatar
Default Re: Straight b20b w/ GSR tranny (jdm4life)
I don't know about the high 13's but for sure 14.1-14.2
I also have a B20Z with 404's but it's not installed yet, Waiting for the valve springs. I won't have the gsr tranny for now but i did start to look for one. Would be a good bang for the buck for me.
The B20 goes in a 1992 Integra RS. Right now i'm running 15.4 @ 88-90mph with a cold air intake, cat back exhaust and full interior.
Any idea of what i'll be running with the new set up....completly stripped?
[Modified by xxplosif1, 8:37 PM 8/6/2002]
Old Aug 6, 2002 | 11:42 AM
SuperCivic's Avatar
Default Re: Straight b20b w/ GSR tranny (xxplosif1)
so xxplosif1 you are running a b20z w/ ls tranny and ls ecu? do you have a fpr installed?
Old Aug 6, 2002 | 11:55 AM
xxplosif1's Avatar
Default Re: Straight b20b w/ GSR tranny (SuperCivic)
I have everything ready for the swap. I have a B&M fpr and some prelude injectors that i'll put in if needed with my nitrous kit.
anything else i should know?
Old Aug 6, 2002 | 02:47 PM
what is ur setup exactly if i may ask?? any fuel management?? i/h/e??
Old Aug 6, 2002 | 02:51 PM
I dont understand how the GSR gearing is benifitial.. as you shift through gears the RPM's drop to 4.5 or even 5 and if ur running a b20b according to all the dynos I've seen the peak output is at 6.. so wat I'm saying is ur only in gear for about 1000 rpm's not nearly enough time to build speed... some please set me straight..
second question.. I'm using a 96 auto ls ecu.. does tht matter??
if so i can use my dx ecu but the motor stalls.. anyone knows wats going on.. (i'm using a gsr wiring harness, dont ask why.. but i am..)
Old Aug 6, 2002 | 04:41 PM
daver's Avatar
shorter gearing is one benefit - providing you get traction, the other is of course closer ratios. Keeps the needle up as high as possible in the band after shifts. Doesn't matter if the peak it at 6k, shift right at redline, providing the power hasn't dropped off too much (more noticable in higher gearing). Even if the power has dropped off some after 6k, its still putting more power to the ground than a sweeter rpm spot in a higher gear.
Is that what you meant mister?
Old Aug 6, 2002 | 08:39 PM
POLLO's Avatar
Its not my setup its a friend of mines.
Ghetto CAI
JDM DC headers wrapped without a cat or exhaust
B&M FPR
LS ECU
This is on a stripped down 92 VX and the guy weights around 130lb.....
Old Aug 6, 2002 | 08:48 PM
willyboyK20's Avatar
Default Re: Straight b20b w/ GSR tranny (daver)
how are the highway rpms with the gsr tranny?
Old Aug 19, 2002 | 11:40 AM
jdm4life's Avatar
Default Re: Straight b20b w/ GSR tranny (willyboyD16)
Kinda high ......but not too bad at around 80mph i am about 3k.....sux if have a loud exhaust like I do but I am about to order and install a resonator inline between the cat and the muffler....it hauls *** even in fifth
Old Aug 19, 2002 | 12:21 PM
Mr. Softee's Avatar
3k at 80mph? you should be at 4k at 80mph with a gsr tranny.
I ran one wtih my LS motor... it was great but NO traction (turbo).
Old Aug 19, 2002 | 12:49 PM
Jeff C's Avatar
plug the gear ratios in here...
http://www.f-body.org/gears/
Old Aug 19, 2002 | 03:21 PM
Newman's Avatar
New User
When I did run that setup, I could either tie or beat my friend's B18C hatch (same year/model hatch, both of us just had intake & exhaust only). He ran consistent 14.4 times at the track on street tires so I'd suspect my car to run low 14s on street tires at the track <-- this was with 98 JDM B20B, 99 GSR tranny, and 95 XS-chipped LS ECU.
Old Aug 19, 2002 | 03:24 PM
Newman's Avatar
New User
Default Re: Straight b20b w/ GSR tranny (Newman)
Oh yeah... on the freeway, going uphill, we were tied in 4th gear (he was in VTEC, I obviously wasn't) but as soon as we hit 5th, he passed me with ease (he was still in VTEC)
Old Aug 20, 2002 | 05:04 AM
hionvtecxda6's Avatar
when i had my str8 b20 w/ a jdm j1 cable tranny i hit 15.7 on street tires in my 92 integra at palmdale, its good off the line but top end sucked ***.
Old Aug 20, 2002 | 10:32 AM
daver's Avatar
Default Re: Straight b20b w/ GSR tranny (hionvtecxda6)
was that a jdm b20b? mr?
d
Old Aug 21, 2002 | 08:38 AM
yes it was a 98 jdm b20b. and the track is 2700 above sea level.
peace
Jimmy
LS_VTECteggy
Oct 19, 2009 08:04 AM
dan_w_82
Apr 25, 2005 03:55 AM
whiteyGSR
May 20, 2004 06:51 PM
rev-speed
Feb 11, 2004 04:47 PM
xaznx
Oct 18, 2002 07:59 AM
