rear disc conversion on my del sol
Old Jan 9, 2009 | 12:14 PM
delfast's Avatar
Default rear disc conversion on my del sol
Hey everyone, I was wondering what i would exactly need to do a rear disc conversion on my del sol. Will any rear disc conversion work like gsr or si and i just need the right e brake cables? Please help!
Old Jan 9, 2009 | 12:47 PM
nix94delsol's Avatar
Default Re: rear disc conversion on my del sol
find a crashed SI/SI Vtec model and rape it of its rear braking components
Old Jan 9, 2009 | 02:11 PM
EL Vap133's Avatar
You can use any 92-00 Civic brakes or 90-01 Integra brakes. As far as e-brake cables, I am not familiar with the Del Sol but I am sure you can use other cables.
Old Jan 9, 2009 | 05:50 PM
delfast's Avatar
Thanks for the info guys greatly appreciated!
Old Jan 9, 2009 | 11:38 PM
litoekneeil's Avatar
the si e brake cable is the longest.
you can also use the del sols disc brake e brake cable
Old Jan 9, 2009 | 11:49 PM
teamworxek9's Avatar
The easiest would be to do what was mentioned up a few and find a set up on a sol in a j/y.
Old Jan 10, 2009 | 05:30 AM
310HPS2k's Avatar
Once converted do you need to change the prop valve? if so to what?
Old Jan 10, 2009 | 06:02 AM
American.Graffiti's Avatar
If you already have a 30/30 or 40/40 you do not need to change the prop valve. Anything outside of those two like a 30/40, you will need to change.
Old Jan 10, 2009 | 06:37 AM
iliv2xlr8's Avatar
You need a 40/40 prop valve for a rear disc conversion. Use one from a 94-01 RS Integra. They are non-ABS, and will bolt right up.
The reason you want to change the proportioning valve is simple. Drum brakes require much more hydraulic pressure than disc brakes. Honda engineers change the proportioning valve bias to compensate, and make braking equal. If you do not swap the valve when you do the conversion, then the rears will have more hydraulic pressure than the fronts.
Many will say that they never noticed a difference, and didn't swap the valve. Under normal driving conditions, this may be true. However, when you need your brakes to perform isn't under normal conditions. The truth is that the rears will lock up much faster under extreme braking. It's a safety issue. It's a performance issue. It's something that can be completely avoided by installing a 40/40 proportioning valve.
Old Jan 10, 2009 | 07:20 AM
delfast's Avatar
So from what you told me, I can either use a si ebrake cable or a del sol disc brake ebrake cable? thanks again guys!!!!
Old Feb 22, 2009 | 07:20 AM
310HPS2k's Avatar
i just got a complete GSR rear disc, will GSR ebrake cable for for del sol??
Kyoto
Mar 8, 2008 11:40 PM
KodSol
Apr 10, 2007 01:10 PM
Eg2707
Dec 21, 2006 12:45 PM
AzntaggeR
12
Aug 6, 2005 04:04 PM
hondabibi
Aug 16, 2004 01:17 PM
