head gasket on f22b
while i was rebuilding my f22b dohc i used a H23 head gasket everything looked fine when i put it on however i was told that it actually doesn't work however i want another opinion. i was told that i needed to use a f22aX head gasket. does anyone know if the H23 head gasket will work or do i need to tear back down and change it. thanks in advance.
I found this on this forum.
Head Gaskets
BORE
H22A = 88mm/3.46
H22A1 = 88mm/3.46
H22A4 = 88mm/3.46
H23A = 88mm/3.46
H23A1 = 88mm/3.46
F20A = 85.5mm/3.37
F20B = 85.5mm/3.37
F22A = 85.5mm/3.37
F22B = 85.5mm/3.37
F22B1 = 85.5mm/3.37
F22B2 = 85.5mm/3.37
F23A = 86.5mm/3.41
THICKNESS
H22A = 0.66mm/.026
H22A1 = 0.66mm/.026
H22A4 = 0.66mm/.026
H23A = 0.66mm/.026
H23A1 = 0.66mm/.026
F20A = 0.66mm/.026
F20B = 0.66mm/.026
F22A = 0.66mm/.026
F22B = 0.66mm/.026
F22B1 = 0.66mm/.026
F22B2 = 0.66mm/.026
F23A = 0.66mm/.026
Note:
Gasket thickness measured after crush
