ZC Parts???
What headers fit the DOHC ZC??
What Oil Filter?? what oil and how much to use??
I'm a newbie on this engine...
I just got my EG swaped with a 92 DOHC ZC and I need headers and oil change so some one please help!!
What Tranny is better: ZC or the 92 to 95 EX/SI....is the ZC available with LSD??
Ok any 88-00 civic header will bolt up but you might want to slightly port match the header. I would buy one for the 92-95 civic and port match the header so the ports on header and motor match up. I would use a 92-95 ex/si trans since your car is setup for a hydro transmission and the ZC transmission is a cable setup. On my 89 ZC I used a 89 integra filter and 4 quarts of oil. Good Luck
Here is what I suggest...Go to your local parts store and look up the part numbers for the oil filter for an 89 integra and a 92-95 civic. I am pretty sure they will be the same. And yes you can use mobil 1 synthetic.
4 quarts of oil is the amount of oil you want to use.
russian_racer
Apr 11, 2003 07:19 PM
