zc ecu
The Si ecu will run the motor but the 89 integra ecu or the ZC ecu will allow the motor to run much better. The ZC and integra ecus have better fuel maps that are better matched to the ZC motor than the Si ecu.
I am running the stock Si ecu with my ZC for now and it runs ok. But I've done a ton of research, and I've decided on the Integra (Pg7) ecu. You get about the same power as the ZC ecu, but it's cheaper, easier to find. . and no damned speed governor at 112 mph.
You will get more power than the Si ECU or the TEG Ecu with the ZC ECU, it has the correct Fuel maps, The TEG runs rich, and the Si while it works is the worst choice. And makes the Least power and has the worst driveability. Yes it has a 112mph speed limiter, that can be chipped to removve it. This subject has been flogged to death. THe ZC has the best maps for the ZC, if you run a TEG or Si ECU they can be chipped with the ZC maps. Do a search. Results will back up what I say. I am running a ZC ECU for that reason.
[Modified by virginia_dude, 8:05 AM 8/6/2002]
4door93civic
Jun 4, 2004 09:42 PM
