exhaust manifold thread size
i just swapped my engine but do not have some parts. i need to know what size studs and bolts i need for the headers to mount to the motor exhaust manifold. i know what size socket i need, i need to know the actual thread size of the bolts and studs. some1 help?
is that the same size for the three bolts that connect to the down pipe? I have a big exhaust leak and wondering what size socket that will fit..my guess would be 14mm? two are studs connected by nuts but one looks like it should be connected by a bolt..any help is appreciated..
Also, the stock manifold and A-pipe are held together by 3 studs w/ nuts on them, no bolts. Sometimes the nut likes to fuse itself to the stud, and the whole nut/stud combo comes out of the manifold, and it's a huge PITA. Even when I try to shoot them off quickly with my impact, the stud still comes out of the manifold.
It's probably the same, and they should be 12mm nuts (6mm thread is typically 10mm bolt head).
Civic Racer X 7
Aug 29, 2014 07:37 PM
Rory Breaker
Sep 15, 2005 05:22 PM
