will a 1994-2001 mishimoto raidator fit a 1993 manuel DA integra?
what up?
i am curious if a 1994-01 acura integra mishimoto raidator would fit directly in a 1993 Da integra without to much modification. All i could find is this.....
1990/92 DA
Core Size: 350mm x 678mm
Rows: 1
Inlet: 32mm
Outlet: 32mm
Core Thickness: 26mm
Tank Wall Thickness: 2mm
Fill Neck: 31mm
1994/01 integra
Core Size: 350mm x 658mm
Rows: 2
Inlet: 32mm
Outlet: 32mm
Core Thickness: 42mm
Fill Neck : 31mm
not to much is differnt....
so any more info would be appricated....
thanks....
1990/92 DA
Rows: 1
Inlet: 32mm
Outlet: 32mm
Fill Neck: 31mm
1994/01 integra
Rows: 2
Inlet: 32mm
Outlet: 32mm
Fill Neck : 31mm
thanks....
yup shure will the mounting tabs may need to be custom due to the cross member
vtecn8ive
Aug 29, 2006 01:10 PM
