Stock Fuel Rail Bore?
Old Jan 8, 2009 | 03:24 PM
accord_raffi's Avatar
Default Stock Fuel Rail Bore?
Anyone know what the bore is on a stock fuel rail for a 1996 accord lx? Right now my car is tuned for 5.8psi. I'm going to retune at 10psi sometime this spring and i'm wondering if their is a huge difference between the bore of the stock fuel rail versus AEM's. I believe AEM has a 1/2" bore. Let me know if you guys think it's worth spending the money on it.
Old Jan 8, 2009 | 04:03 PM
Turbowa's Avatar
Default Re: Stock Fuel Rail Bore?
I hope your running more then 5.8psi of fuel. You should be around 45psi, as for the fuel rail, unless you need the extra port on the top just stick with the stock unit. There's no need to waste the money. You won't gain any thing.
Old Jan 8, 2009 | 05:19 PM
GhostAccord's Avatar
The stock rail is 11.31mm or 0.445in. There is no need to pay for an AEM rail when it is only 1.39mm or 0.054in larger. It won't make any difference in your builds performance.
Old Jan 8, 2009 | 05:39 PM
hahaha sorry i should have been more specific. My ecu is tuned for 5.8psi of boost on Crome. As for my fuel psi, i believe a stock accord's fuel psi is 38psi, right?
Jesus, that's not even a tenth of an inch larger haha. So as stated earlier, the only other advantage would be the extra port. I'll put this money towards injectors or something.
Quickridez_3
Dec 22, 2022 11:18 AM
racekar711
Nov 22, 2005 12:13 PM
TypeRuz
Nov 19, 2003 11:40 AM
Rice Ball
Mar 26, 2003 02:24 PM
blackteg
Jul 16, 2002 11:06 AM
