check engine light/shift light
Old Jan 8, 2009 | 03:09 PM
phonetxt's Avatar
Default check engine light/shift light
my bro has a 99 civic si as do i
he is boosted and has a chipped obd1
im planning on trading my car for a crx with gsr w/ obd1 or maybe another w/ b16a2 w/ obd1
his check engine light pops on when it hits 8200rpm
and i was wondering how could i do that to the crx obiously to my readline
and also does this only work with the check enine?
or are there more and can you do it with multiple ones at a time?
and one more thing what stock gauge clusters fit crxs goes at 9000rpm
cuz im not interested in a 5" 'autozone special' tach
Old Jan 8, 2009 | 03:20 PM
hfrex's Avatar
Default Re: check engine light/shift light
someone who chippes ecus might do it who knows? im running hondata and my shift light is the check engine warning light!!!
Old Jan 8, 2009 | 03:22 PM
Radim's Avatar
You can set up an LED Shiftlight into the check engine bulb socket behind the cluster which would light up the check engine light when the light itself turns on.
Old Jan 8, 2009 | 03:24 PM
hfrex's Avatar
true!!!! you could do the same with the vtec!!!! i ran one of those little alarm lights by my cluster as my vtec and check engine as my shifter light!!!!
Old Feb 4, 2009 | 04:58 PM
1phatEG8's Avatar
which wire (on the v-tec) did you hook the light to? the pressure switch?
Boosted_B_Series
Audio / Security / Video
Dec 22, 2009 10:46 PM
924drcivic
20
May 31, 2009 12:05 PM
phonetxt
Jan 14, 2009 10:17 PM
phonetxt
Engine Management and Tuning
Jan 10, 2009 04:55 PM
Devious951
May 29, 2007 04:43 PM
