1990 Accord will not start/ Where to go next?
Old Jan 8, 2009 | 02:29 PM
Just_me_chris's Avatar
Default 1990 Accord will not start/ Where to go next?
Hi there, I have a 1990 Accord and it wont start. I had to replace the battery about a month ago. Then the yesterday I was running errands came out of a store and the car would not start.
I put the key in, turn it and I get no noise, no click, no starter trying to turn etc. My interior and exterior ligths burn bright and all that. I tried to jump start it and still got nothing.
I am unemployed and going to need to do the work myself, but Im just not sure what to check next. I am thinking starter. Can someone maybe give me a flow of what to check next? I can start pulling parts like the starter or alternator and take them to Orielys and let them test them, but that seems a little crazy to do randomly.
Any advice would be great, I have to get this car running so I can keep on interviews and find a new job.
thanks,
Chris
Old Jan 8, 2009 | 03:32 PM
P_Adams's Avatar
Default Re: 1990 Accord will not start/ Where to go next?
thanks,
Chris
If it's a manual Transmission, you've got a Starter Safety Switch located on the pedal hanger just behind the clutch pedal.
If it's an Automatic, you've got a neutral safety switch located on the shifter mechanism.
If you're proficient with a 12v test light, probe the signal wire which connects to the Starter Solenoid and see if you have power (when the key is turned to the 'start' position).*
If you do, suspect the starter
If you don't, most likely one of the two switches i mentioned is at fault.
P
* caution is warranted, it could start.
Katie Stanley
Aug 1, 2017 07:23 PM
mohmandem
Jul 4, 2012 10:47 PM
jwicecold
Aug 6, 2011 10:00 PM
hometheaterman
May 7, 2006 10:15 PM
