squeaks over bumps?
Old Jan 7, 2009 | 08:28 PM
dleccord's Avatar
Default squeaks over bumps?
i have a few blown ball joints for my 96 honda accord. could this be the problem? i believe my shocks are gone too by looking at the oil that seeps out by the shaft of the shocks.
my dad took it to his friends house and was told that the noise would go away by replacing the shocks.
so my question is, could it be the shocks that is causing the squeaky noises or the ball joints?
Old Jan 7, 2009 | 08:40 PM
P_Adams's Avatar
Default Re: squeaks over bumps?
Ball joints. They've a history of squeeking when the cold season arrives.
I'd also have the sway bar bushings checked as well
P
Old Jan 7, 2009 | 08:45 PM
The-Kid's Avatar
I second the sway bar bushings. Same problem, but got it fixed with a little lube.
Old Jan 7, 2009 | 09:18 PM
dleccord's Avatar
well its confirmed that only my right side squeaks when i push the front end down.
oh and i believed it started this summer.
what should i do with the sway bar bushings? is there a lube i have to apply or something?
Old Jan 8, 2009 | 05:22 AM
P_Adams's Avatar
I'm still convinced it's a ball joint, but if you insist- you can spray some penatrating oil on the inner Sway Bar bushings to confirm that that's the problem.
If it does, they will require replacement
P
Old Jan 8, 2009 | 10:55 AM
Ronin1's Avatar
The way you talk about having "a few blown ball joints" makes me nervous. Check out the ball joints, and soon. If one fails completely it can ruin your whole day.
Struts are important too, but I would first be concerned about the ball joints. If your budget permits buying struts and ball joints at the same time it will save you and your dad some work as compared to doing them separately.
Sway bar bushings are easy to replace if they are worn, as they most likely are.
Old Jan 8, 2009 | 12:25 PM
defaced8's Avatar
I'm going with ball joints. Before I replaced my passenger front lower ball joint, my car did the same thing. Squeaked when I went over bumps. Like the post said above, I would also recommend doing the shocks and the ball joints at the same time.
Old Jan 8, 2009 | 08:12 PM
dleccord's Avatar
will the shocks sold over at kragens or autozone do the trick? anyone here had problems with their oem shocks? i think they run about $50 per shock/strut.
Old Jan 9, 2009 | 02:40 AM
P_Adams's Avatar
I wouldn't send YOUR mother-in-law to Autozone, let alone buy parts from them.
OEM Honda will be more than satisfactory for a daily driver, and they're superior to such manufacturers as Gabriel or Monroe. I've 224k on the originals on my SE and still going strong.
KYB makes a good series of replacement shocks. You might consider them.
P
Old Jan 9, 2009 | 05:32 AM
dtapia's Avatar
Originally Posted by p_adams
i wouldn't send your mother-in-law to autozone, let alone buy parts from them.
oem honda will be more than satisfactory for a daily driver, and they're superior to such manufacturers as gabriel or monroe. I've 224k on the originals on my se and still going strong.
kyb makes a good series of replacement shocks. You might consider them.
p
x 2
Old Jan 9, 2009 | 09:04 PM
dleccord's Avatar
P
What's wrong with Monroe or Gabriel?
And how much do the Honda OEM shocks run for?
Old Jan 10, 2009 | 01:27 AM
Skip888's Avatar
from what i have see ill put my money on the ball joints
Old Jan 10, 2009 | 03:45 AM
Geoff eg6's Avatar
y not change both. If they are both f**ked then change out the lot then no worrys
Old Jan 10, 2009 | 03:17 PM
dleccord's Avatar
Old Jan 10, 2009 | 04:48 PM
P_Adams's Avatar
I gave up on them in the mid 80's when i was pinched between lousy support on the jobber level and I had a run of warranty claims (8 customers in 5 months) where i lost money on that trash. I had better luck with Delco.
For Honda's I use KYB's
The GR-2 series for Daily Drivers sell for about (259.00/set)(about 69.00/each)
The AGX series for Twisty Drivers sell for about (474.00/set)(about 115.00/each)
If U searched, U could find them cheaper
The Honda OEM's wholesale at 86.00/each Front / 89.00/each Rear
Old Jan 10, 2009 | 05:26 PM
dleccord's Avatar
Can I reuse the OEM rubber mounts that is currently on my Accord? Where can I buy bump stop because there isn't one on my shocks.
Old Jan 10, 2009 | 05:53 PM
P_Adams's Avatar
If they've been in there like, Forever; I'd entertain replacing all the mounting bushings as well. You'll most likely destroy the old ones trying to get them out anyway.
You may be able to get them from
Honda (Obviously)
TAS Auto Parts
or I've even found them on
TireRack.com
Old Jan 11, 2009 | 03:38 PM
rjHella's Avatar
i got a 96 accord &my **** is squeaking of late also but ive been told its my shocks.
deeweezy187
Dec 31, 2008 01:33 PM
mark2583
Nov 10, 2008 01:35 AM
Nizzy
Nov 7, 2003 12:26 PM
96GSR
Oct 1, 2001 01:15 PM
