Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
07 oem radio/navi swap help
Old Jan 7, 2009 | 07:15 PM
clusterfunk's Avatar
Default 07 oem radio/navi swap help
tryed searching, sorry.
basically i need all the info. my girl just got an 07 and she wants the stock navi. need to know what i need to swap the stock radio out for a stock navigation. can i do this with any model? is there a seperate "brain" that i need to buy? any and all info on the subject would be a great help. thanks.
Old Jan 7, 2009 | 10:01 PM
Default Re: 07 oem radio/navi swap help
http://s243.photobucket.com/albums/f...rent=honda.jpg this is what she has now if it helps
Old Jan 11, 2009 | 04:23 AM
skizot's Avatar
I have written a couple of threads in detail with pictures on v6performance.net and gen7accord.net.
First, you do not have dual climate control, so you might as well forget about doing this. Being honest.
This is not an easy swap. You need the following pieces in order to do it:
Navigation head unit
Navigation DVD drive for trunk, plus all mounting brackets
GPS receiver for under the rear deck lid
Top panel for dash
Sub Display for top panel on dash
A custom built wiring harness for both the sub display and for the DVD drive
A lot of patience as you will need to completely rewire your heating and AC as you do not have dual climate control.
While not required, if you want the talk back system, then you will need the switch for the steering wheel and the microphone as well. You are looking to spend between $1500-$2000 to do this conversion and making your own custom wiring harness is not easy. There used to be a guy that was making one for $350, but I do not think he makes them any longer.
Long story short, trade the car in and buy one with navigation already in it. In your case, this is not impossible (it has been done before), just timely and very costly.
Old Jan 11, 2009 | 08:36 AM
This is a huge help, thank you so much. If it was my car i would do it for sure, but since its my chicks and she will forget i even went on the mission for her i wont. guess i will be getting a nice garmin and cramming it under the radio. thanks again.
cmc600rr
Feb 16, 2010 05:33 PM
nycnftm
Jan 26, 2009 07:18 AM
JS29
Acura TSX
Jan 23, 2009 08:30 AM
the big read
Acura TSX
Oct 8, 2008 07:02 PM
EJ1_R
May 25, 2005 06:56 AM
