need help w/ problem after jdm header and carsound cat installed......
Old Aug 5, 2002 | 04:28 PM
Another_Teg_Owner's Avatar
Default need help w/ problem after jdm header and carsound cat installed......
i just installed a jdm itr header and a carsound cat on my 2k gsr. i ran out of money to get an exhaust so i'm temporary using my stock b-pipe. my engine is basically stock with a cai. after the installation, i went out for a drive, and i notice a sound coming from under the car. everytime i rev pass 3.5 rpm i notice a "hisst" sound. i went home and on neutral, i rev it to 3.5 and let go the gas, i hear the same sound. it seems like its coming from the cat. the "hissting" sounds like a leakage or blow out valve (which i don't have)....does anyone know whats wrong?...everything seems to be tight...
also, i already reset the ecu after the installation...
Old Aug 5, 2002 | 04:29 PM
NWPNOMORE's Avatar
Banned
Default Re: need help w/ problem after jdm header and carsound cat installed...... (Another_Teg_Owner)
it's normal, almost everyone gets the same results when combining the two. My header and exhaust is so raspy, but it's nothing to worry about.
Old Aug 5, 2002 | 04:42 PM
oryanh's Avatar
Default Re: need help w/ problem after jdm header and carsound cat installed...... (NWP4LIFE)
Same noise here.
Old Aug 5, 2002 | 04:47 PM
so whats causing the noise... the combo of the jdm header/cat or the cat/ b-pipe?
any power loss from the noise?
Old Aug 5, 2002 | 04:51 PM
underrated99si's Avatar
probably the bottle neck were the cat and the bpipe meet up they are mismatched
Old Aug 5, 2002 | 04:52 PM
oryanh's Avatar
Default Re: need help w/ problem after jdm header and carsound cat installed...... (underrated99si)
I had my bottleneck cut out, and a new flange put in.
-still makes noise.
Old Aug 5, 2002 | 04:53 PM
NWPNOMORE's Avatar
Banned
it's the header, it makes that noise.
Old Aug 5, 2002 | 04:57 PM
Asahi's Avatar
depending on the volume of the noise it could be that the flanges are not bolted tight enough.
have a shop hit them aith air tools
Old Aug 5, 2002 | 05:43 PM
Dave-ROR's Avatar
the fix is easy imo.
do this
step 1: turn the **** labeled "volume" on the radio to a higher setting
that's all it takes and the problem is resolved.
Old Aug 5, 2002 | 05:51 PM
Tommy_Gunns's Avatar
Default Re: need help w/ problem after jdm header and carsound cat installed...... (SoFreshAndSoCleanClean)
That's your answer to everything. I knew I should have kept those subwoofers from my other car
Old Aug 5, 2002 | 06:10 PM
Willard's Avatar
less mass = less ability to absorb noise from the motor.... that is why the valve noise is louder with the heder on.
Old Aug 5, 2002 | 06:24 PM
Dave-ROR's Avatar
Default Re: need help w/ problem after jdm header and carsound cat installed...... (Tommy_Gunns)
just to "werid noise"/"rattle" complaints. We don't drive heavily overdampened lexus' here do we? expect some damned noises/rattles.
Old Aug 5, 2002 | 07:52 PM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
its just the blow off valve that comes with the cat
Old Aug 6, 2002 | 01:17 AM
Default Re: need help w/ problem after jdm header and carsound cat installed...... (RealTypeR)
wow..free blow off valve...but then, its a little ricey b/c i don't have the turbo to back up that "blow off valve"...
98R-1144
Jun 13, 2006 02:01 PM
StinkyTofu
Feb 16, 2003 12:27 AM
sushibug
Aug 15, 2002 12:06 PM
oryanh
Aug 5, 2002 12:31 PM
citanest
Jul 19, 2001 12:41 PM
