Selling 95 DEL SOL SI/Trade.
Old Jan 7, 2009 | 02:43 PM
DeLsLo95Si's Avatar
Default Selling 95 DEL SOL SI/Trade.
Its a honda del sol, want $3k/obo or a trade.
ENGINE
del Sol Si
Type: Aluminum Alloy in-line 4
Displacement (cc)
1590
Horsepower @rpm (SAE net)
125@6600
Torque (lb-ft.@rpm)
106@5200
Compression Ratio
9.2:1
Valve Train: SOHC 16-Valve
VTEC
Fuel System: Multi-Point Fuel Injection
Ignition System: Electronic
Drivetrain
del Sol Si
Type: Front Wheel Drive
Manual Transmission: 5 Speed
Automatic Transmission: 4-speed (available)
FInal Drive Ratio (MT/AT)
4.25/4.33
Body/Suspension & Chassis
del Sol Si
Body Type: Unit Body
Suspension: 4-Wheel Double Wishbone
Stabilizer Bar (mm, front/rear)
21.0/NA
Steering Type: Power Rack-and-Pinion
Turning Diameter: Curb-to-Curb(ft)
30.8
Power-Assisted Front Disc/Rear Drum Brakes
na
4-Wheel Disc Brakes
Anti-Lock Braking System (ABS)
na
Wheels
14" Alloy
Tires: All-Season
P185/60 R14 82H
Exterior Dimensions
del Sol Si
Wheelbase (in.)
93.3
Length (in.)
157.3
Height (in.)
49.4
Width (in.)
66.7
Track (in., frt/rear)
58.1/57.7
Curb Weight (lbs. MT/AT)
2414/2474
Removable Roof Panel (lbs.)
24
Interior Dimensions
del Sol Si
Headroom (in.)
37.5
Legroom (in.)
40.3
Shoulder Room (in.)
52.9
Hiproom (in.)
49.3
Usable Cargo Volume (cu. ft. empty/top stored)
10.5/8.3
Interior Passenger Volume (cu. ft.)
47.8
Also:
  • it has civic hatch seats in it.
  • 33mpg
  • Has been using Pennzoil HM since I have had it.
  • All mantince has been kept up, I work at a shop.
  • Stock alloy rim's are on it.
  • New Tires.
Want anymore Info or pics PM me
DeLsLo95Si
Jan 15, 2009 09:41 PM
clemsonhatch
Wheels
Apr 5, 2008 01:29 PM
andrew dc
Dec 27, 2002 08:59 AM
