cutting shift linkage?
Old Jan 7, 2009 | 02:36 PM
turbo-crx's Avatar
Default cutting shift linkage?
i have the linkage for the 90-93 integra for my b16 crx. Where do you have to cute and weld the linkage together? i know you have to cute it 2-3/8'', does it matter where you cut and weld it?
Old Jan 7, 2009 | 02:44 PM
JScott3d's Avatar
Default Re: cutting shift linkage?
you want to cut in the straightest section. I do not know about the 2-3/8" I did that once and it hits the front of the console. I did a different set a 2" and it centered it much better. You may just want to cut them and then remount them and see how much you do need to cut.
Old Jan 7, 2009 | 02:45 PM
turbo-crx's Avatar
thanks man. ill do the 2'' cut first.
Old Jan 7, 2009 | 02:46 PM
gibsanez's Avatar
I cut out 2" or so and stuck a bolt back into the shaft to keep it straight and to give me something to weld to.
Old Jan 7, 2009 | 04:36 PM
northemt88's Avatar
i think it is the 2 3/8 "
i just cut mine on the straightest part i could find and i came out good except my friend doesnt know how to hold stuff straight, but otherwise it works fine
slowcrx954
Sep 18, 2007 06:11 AM
MugenCRX89
Jul 22, 2007 07:15 PM
N1ghtM0nkey
Mar 2, 2005 04:24 PM
Exodus1811
Feb 29, 2004 01:20 AM
b16pwrcrx
May 29, 2003 02:30 PM
