Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Clanking noise rear left shock/strut assembly
Old Jan 7, 2009 | 11:45 AM
vjsarthy's Avatar
Default Clanking noise rear left shock/strut assembly
I have 2006 Honda Accord with 38000 miles on it. Recently I hear a clanking noise in my rear left shock absorber whenever I hit a bump or pothole, both in high and low speeds.
Does the outside temperature matters? Because when the weather is warm, I dont hear it but when its cold I hear it.
I dont know what the problem is. Any suggestions/advice would be useful.
Thanks in advance.
Old Jan 7, 2009 | 11:55 AM
MSchu's Avatar
My Name is Nobody
Default Re: Clanking noise rear left shock/strut assembly
there are a few things it could be. from a loose exhaust hanger to a loose mount point on the shock assembly itself. you need to get up under there and have a loook around. I wish I could be more help from afar
Old Jan 7, 2009 | 12:02 PM
Crono139's Avatar
Check out the brackets on the rear sway bar.
Old Jan 7, 2009 | 01:56 PM
vjsarthy's Avatar
So its got nothing to do with the outside temperature. I clearly see the difference with change in temperature.
Old Jan 7, 2009 | 03:53 PM
boostedwagon's Avatar
if i had to put my money on something i'd say its the rear sway bar endlink.....
tortuga89's Avatar
i think that may be some bushings that are dry
Ethylment
Honda CR-V & Element
Mar 8, 2015 10:39 AM
jjr_99prelude
Oct 17, 2007 06:53 PM
Shizznaz
Suspension & Brakes
Mar 20, 2005 07:36 PM
Feuerraeder
Jun 18, 2003 01:17 PM
Solracer
15
Jun 15, 2002 07:37 PM
