Caster
Old Jan 7, 2009 | 01:04 AM
Tysnet's Avatar
Default Caster
I recentely crashed my car into a mound of dirt because of slippery road conditions. It wasn't bad at all. It threw my alignment off but no physical damage at all. So I had ordered a camber kit already and was going to install it before this happened. Luckily I waited... So before taking my car to the shop for the alignment I installed the camber kit. Smooth... Take her in for the alignment... The camber is perfect... The toe is perfect... But the caster is only able to get within 1 degree of perfect. They said it could be the bushings for the lower control arms, either side, or something else even. Anyone got a good idea of what part it could be? I just replaced all the bushings in the front end like 6 months before this happened. I really don't want do it again...
Old Jan 7, 2009 | 03:41 AM
fireant's Avatar
Default Re: Caster
You can add a washer between the radius rod bushing and subframe to get a little caster adjustment. You can also adjust the front crossmember a little by loosening the bolts and moving its play with a pry bar. Take a look at the front radius rod bushings first.
Old Jan 7, 2009 | 08:57 AM
93formula's Avatar
Default Re: Caster
or if you upgrade to a tracion bar setup you can adjust caster that way.
turbo-crx
Suspension & Brakes
Dec 31, 2008 06:37 AM
integraboi1010
Oct 21, 2006 03:51 PM
SIRIUS
May 27, 2005 05:48 AM
VTEConly
Sep 27, 2004 11:43 AM
maxQ
10
Dec 5, 2003 07:22 AM
