Main relay bad on cold starts also?
Old Jan 6, 2009 | 05:48 PM
Blazinmiller's Avatar
Default Main relay bad on cold starts also?
I had an issue when I start my car in the morning or after sitting awhile it will start for a split second and then die.
It will usually start right up after failing the first time.
It's happened when the engine was at op temp but it's happened way more consistently on a cold start.
I've had my main relay go out before 3 years ago and it was the classic symptoms so I'm really doubting that it's the main relay.
I was thinking maybe the ignition module but I don't know the symptoms of that.
Old Jan 7, 2009 | 04:32 PM
slomofo's Avatar
GDD Member
Default Re: Main relay bad on cold starts also?
Check your fuel system first.
Old Jan 7, 2009 | 05:20 PM
I can't cause I never know when it's going to do it.
I'd have to wait until it become constant.
I was doing some reading about the main relay and the click that it makes.
This morning I didn't hear the click so I back off the ignition and tried again and heard the click so I turned it over and it started up fine.
The rest of the day it worked fine.
Old Jan 7, 2009 | 06:25 PM
HONDAPARTSMANMIKE's Avatar
can you say main relay. i would have to say its bad. just replace it i would get it from honda. i hope thats were you got the first one.
Old Jan 7, 2009 | 06:50 PM
P_Adams's Avatar
Have you been plagued with phantom stalls, or it just quiting for no apparent reason?
Next time you go to start it cold, take a moment / turn off the radio / turn the key to the 'run' position and see if you can hear the fuel pump cycle.
There are several possibilities here:
1) Main Relay or
2) Ignition Switch (electrical portion)
3) Ignition Ignitor (module)*
Let me know what you find
P
* involved in a recall for the '90 model year. And although they failed such that the engine wouldn't start, I've seen some do strange things cold.
Old Jan 8, 2009 | 09:33 AM
1) Main Relay or
P
It's never stalled during general use. The only time I would say that it's "stalled" is when I go to start it and it will die instantly right after catching only to start right up after that.I had a 92 S-10 blazer that had a bad ignition in the distributor and it would cut out even while driving. Didn't matter when it would just cut in and out.My honda's never displayed that kind of issue, it's just on starts.
Old Jan 8, 2009 | 10:18 AM
P_Adams's Avatar
Can you hear the pump cycle?
Old Mar 12, 2024 | 10:32 PM
eksine's Avatar
I'm having the same issue 2001 accord V6, a manager that runs the walmart DC shop for our semi trucks suspects the same thing, main fuel relay. I have an odyssey so I'll be able to check first thing in the morning when it's cold. tell me what your fix was please. I've replaced battery, alternator, spark plugs, tested coil plugs which were all good, replaced fuel pump, and starter. I did fix my fuel economy, it was bad before. I was suspecting idle air control and plugged catalytic converter but manager said engine should still start, just rough. I also suspected fuel pressure regulator. fuel main relay does work, just didn't think to check if it also works during the cold mornings.
peteyparado
Feb 9, 2014 07:38 PM
hondatuner020
Audio / Security / Video
May 18, 2010 11:15 PM
nismogrendel
Apr 24, 2010 01:43 AM
ninjarich2
May 11, 2007 12:51 AM
SouLaQuaRiuS
10
Jun 18, 2003 08:42 AM
