Clutch Kits?
I second the Exedy Stage 2. Or if you can spend a little more cash I would go for a Clutchmasters FX300. The disc has a segmented Kevlar facing. It engages very smooth and last much longer than organic.
The FX300 is a stage 3 clutch. But the FX200 also uses a steel backed kevlar disc. The Exedy kit is "Cerametallic" which means nothing more than semi-metallic, or metal fragments combined with ceramic, which is also very durable. Either way the quality will be top notch, the kevlar seems more appealing though, but I've never driven a kevlar clutch. My Exedy is smooth as butter.
The FX200 uses a full-faced kevlar lining and the FX300 uses a segmented kevlar lining. There's no other difference between them. The segmented kevlar holds more power since you are spreading the clamping load over a smaller surface area. I always reccomend the FX300 over the FX200 because of this. There is no added cost, same pedal pressure, same reliability, no reason not to step up.
I'm not slamming the Exedy, they make a good product, but for DD/track car the kevlar is hard to beat.
