do you have to change brake pads in pairs?
Probably a stupid question... and pads really aren't that expensive. But I'm curious, what if for example, you have two OEM Acura pads but one is more worn than the other? I'm talking about front brakes.
They sell as a set for a reason...
In all honesty, nothing will really happen- as the piston and sliders take up the extra room created by the thinner pad...but an extreme difference in pad materiel under hard driving will definitely cause an issue.
It isn't the calipers causing uneven wear, it's just because I hit a curb which shattered my rotor and basically dug some chunks out of the pads on that side, and the replacement suspension that I'm putting in the car already has pads with it.
thats fine just make sure to scuff up the older pads with some fine grit sand paper, in the direction the rotor spins. deglaze the pads.
make sure to lube up the caliper slides as well.
