STD motor VS DX motor ?
Old Aug 5, 2002 | 01:08 PM
89dxhunchback's Avatar
Default STD motor VS DX motor ?
Why does the Std motor only make 70 Hp, when the DX motor has the same DPFI and 1.5L, but the DX makes 20 more horses ?? I'm fixing to buy a STD. car for $100.00, and I was thinking mini-me, since I'm turboing my current DX.... Thanx..
Old Aug 5, 2002 | 01:37 PM
Aphrodavid's Avatar
Default Re: STD motor VS DX motor ? (89dxhunchback)
2 things make the big difference between the STD and DX motor
DX=16 valves
STD=8 vavles
DX=9.2 to 1
STD=9.1 to 1
Old Aug 5, 2002 | 01:39 PM
DJ KrunchyKracker's Avatar
Default Re: STD motor VS DX motor ? (DX-R)
also cams prob make a pretty good difference. they make 5 hp between the 88-89 and the 90 91 see our x si's
Todd00's Avatar
I said I don't want a title!
DX=16 valves
STD=8 vavles
DX=9.2 to 1
STD=9.1 to 1
Yep, what he said. However, only 1 thing IMO-- 8 vs 16 valves.
Old Aug 5, 2002 | 04:12 PM
714phil's Avatar
DX=16 valves
STD=8 vavles
DX=9.2 to 1
STD=9.1 to 1
i had 16 valves on my std motor
Old Aug 5, 2002 | 05:57 PM
4gvtec's Avatar
yes the std is 16 valves.
Old Aug 5, 2002 | 07:54 PM
nsxmatt's Avatar
Default Re: STD motor VS DX motor ? (4gvtec)
Yes, standard has 16 valves. I put a dx head on my old 90 std and it picked up a bit. The cam is the only thing I could tell that was different. ECU's, intake, exhaust, and block are the same. The tranny is also a weak point with only 4 gears and no overdrive. My 4-speed std with dx head ran a 10.9 1/8th stripped which is slow but much faster than it would go with 70hp.
Old Aug 5, 2002 | 08:11 PM
ViperRedCRX's Avatar
Default Re: STD motor VS DX motor ? (nsxmatt)
from what i understand the motors are the same, just some points of the car changed. like pass. side mirror, tach, clock, and little stuff like that
curt801
Feb 27, 2006 06:30 AM
smash fascism
Aug 28, 2005 08:57 PM
wu tang
23
Aug 11, 2002 12:34 AM
