Will the FITV affect my throttle response?
Old Jan 5, 2009 | 04:28 PM
jose310's Avatar
Default Will the FITV affect my throttle response?
Well i have surging idle, and was wondering if that have an affect on the cars performance?
Old Jan 5, 2009 | 04:34 PM
P_Adams's Avatar
Default Re: Will the FITV affect my throttle response?
Not likely, but it could be indicative of other factors that could.
Low coolant level
Insufficient coolant tempurature
Vacuum leaks
etc
The FITV (Fast Idle Thermal Valve, does just that; effects fast Idle. It does this by by sampling Coolant Tempurature and inducing additional ait to the intake tract.
P
Old Jan 5, 2009 | 04:40 PM
jose310's Avatar
Ok thanks adam!, I cleaned the egr ports on my accord today and were plugged up, feels a bit better now, is there any other thing i can do or clean on engine that could improve the performance?
Old Jan 5, 2009 | 07:38 PM
P_Adams's Avatar
There's a thread in the FAQ section (page1 of this forum) which covers the cleaning of the Throttle Body and the IACV (Idle Air Control Valve)
It is an often overlooked service which can effect drivability.
A little more involved proceedure is decarboning of the Combustion Chambers.
P
Old Jan 5, 2009 | 08:06 PM
jose310's Avatar
is cleaning the iacv a difficult job? the screws and bolts look tricky.
Old Jan 5, 2009 | 08:25 PM
P_Adams's Avatar
It's caused more than it's share of heartache, but it's certainly do-able. If they're the least bit corroded, you might want to put it off until the weather's warmer or till a time where you can take your time.
For the time being, try cleaning the throttlebody (inside) with a spray can of carburetor cleaner. You want to remove any PCV residue which may have accumulated around the throttle plate.
P
Old Jan 5, 2009 | 08:50 PM
johnlear's Avatar
Banned
The IACV can cause problems with throttle response, i.e. it can make TR erratic, which manifests as difficulty when rev matching for down shifts, making it harder than than it should be to make 'clean' down shifts (i.e rev rise tend to be less or more than expected when 'blipping' the throttle).
The IACV also tends to prevent the rpm from dropping instantly the moment the butterfly valve is shut, meaning rpm tend to 'hang' momentarily (or a bit longer...) when you are shifting up (or at least to not fall as sharply as would be the case should the IACV not exist).
I strongly recommend blanking off the ports into (or out of) the IACV for improved driveability (i.e. shifting), so long as you don't mind the idle speed being affected by auxilliary loads such as air con etc.
PS This is only an issue for manual box cars, not automatics.
Old Jan 6, 2009 | 01:29 PM
jose310's Avatar
ok well my is an auto, can i get some diy pictures?
Old Jan 6, 2009 | 03:31 PM
P_Adams's Avatar
How about a do-it-yourself thread?
FITV Valve:
https://honda-tech.com/forums/showthread.php?t=1003988
P
Old Jan 6, 2009 | 03:33 PM
P_Adams's Avatar
.......And This:
Throttle Body and IACV Servicing
https://honda-tech.com/forums/showthread.php?t=1844067
P
Old Jan 6, 2009 | 04:19 PM
jose310's Avatar
Seen that be4 but the pictures are no good
gabrielsousa
31
Aug 18, 2014 04:20 AM
shotoutacc0rd
Transmission & Drivetrain
12
Jul 28, 2014 05:50 PM
