Easy accord audio question
Old Aug 5, 2002 | 12:57 PM
Infadel's Avatar
Default Easy accord audio question
What size are the front/rear speakers? 6.5" ?
Also, how do I get the panelling off the front door so I can replace the speaker.
I have a 91 accord SE
Old Aug 6, 2002 | 04:59 AM
Stew Pidasso's Avatar
Default Re: Easy accord audio question (Infadel)
You probably will get a better response in the Audio/Security forum.
Old Aug 6, 2002 | 05:11 AM
YeuEmMaiMai's Avatar
remove the two screws one in the panel and one in the handle, remove mirror cover, gently pry off panel
Old Aug 6, 2002 | 02:23 PM
briq4's Avatar
Default Re: Easy accord audio question (YeuEmMaiMai)
if you go to http://www.crutchfield.com you can choose speakers then your car, it asks for specifics, Model, Trim, Coupe/Sedan, even asks if you have the Bose system which if you did you would have a hard time doing the radio due to the Bose having an amp and the head unit putting out a line level and then running to the trunk... OK TOO Much Info... Anyhow check them out pretty helpful.
If it's anything like the 93 EX it had this plastic speaker box that I took out and there is room to mount a 6.5, I got pioneers that fight right in the speaker baskets that come on the DX (DX was 6.5 and EX was 5" speakers in the front)
[Modified by briq4, 6:35 PM 8/6/2002]
wagonator
May 30, 2011 07:03 AM
k1ngkev1n1
Jun 24, 2008 12:36 PM
uber_mike
Jun 20, 2008 09:08 PM
scissorfighter
Audio / Security / Video
Mar 2, 2004 02:32 PM
RoAnSa
Jan 1, 2003 12:27 AM
