b18c5 swap done, car runs bad, missfire !Help!
Old Jan 5, 2009 | 01:45 PM
Karna's Avatar
Default b18c5 swap done, car runs bad, missfire !Help!
hey, i just finished a b18c5 engine swap into my 94 eg. im using a chipped ecu with a stock type r basemap tune. The car starts but runs very bad, it shakes at idle and seems like its missfiring.
i dont know if this matters but if i unplug my maf sensor it still stays the same, in other words the engine dosnt change sound, i dont know if thats a normal thing.
i just tried a friends 98 jdm type r ecu and it ran the same but with that ecu i was getting 2 codes:
20 Electrical load detector
41 Primary oxygen sensor heater
with my chipped ecu i had no codes
can anyone help me out in any way?
thanks alot
Old Jan 5, 2009 | 01:47 PM
Happyfeat2006's Avatar
Default Re: b18c5 swap done, car runs bad, missfire !Help!
thanks alot
Bent valve maybe?
Old Jan 5, 2009 | 01:50 PM
Mashimaro's Avatar
thanks alot
I wouldn't worry about the ELD code. however, you may want to replace your O2 sensor.
anyways, from the sounds of it, have you checked your spark? perhaps the plug wires were put in the wrong order on the dizzy? just some suggestions, but it sounds spark related.
Old Jan 5, 2009 | 01:55 PM
Karna's Avatar
i checked the spark and its there, double checked my wiring and it seems good. also the engine came out of a running car that ive seen running before pulled and it seemed to run good then
Old Jan 5, 2009 | 07:27 PM
Try doing a compression test.
Old Jan 5, 2009 | 09:18 PM
flipkc's Avatar
MAP and TPS plugged in backwards? Change your O2. Check your timing. ELD is a ghost code.
joel.j.tellez
15
Dec 9, 2013 09:35 AM
mmmbarp
Oct 31, 2010 06:50 AM
91EF_Si
Mar 26, 2008 08:10 PM
91EF_Si
Mar 25, 2008 08:46 PM
94CivSi
May 1, 2003 07:06 PM
