Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
5 and 6th gear rev limiter
Old Jan 5, 2009 | 01:22 PM
07FG2's Avatar
Default 5 and 6th gear rev limiter
I was wondering if it was possible to hit the rev limiter in 6th gear, has anybody hit 5 & 6th gear limiter?
Old Jan 5, 2009 | 01:24 PM
HamiltonRex's Avatar
Default Re: 5 and 6th gear rev limiter
put your car in 5th or 6th, put your foot on the clutch, and put the pedal to the metal, and you will hit the rev limiter in '5th' or '6th' gear.
Old Jan 5, 2009 | 01:25 PM
K5^'s Avatar
K5^
Brand New
Try it out.
Old Jan 5, 2009 | 01:45 PM
Alex_G's Avatar
Occupy GDD
You might be able to in 5th but it wouldn't be legal on any roads around here. 6th would be almost impossible unless you were making alot more power. Why do you care?
Old Jan 5, 2009 | 03:36 PM
clemsonhatch's Avatar
Perfect question for bizzybear...hope he makes a video to show us.
To answer your question, yes in 5th and no in 6th. The Si is speed limited to 133 mph so it won't reach rev limit in 6th.
Old Jan 5, 2009 | 04:25 PM
100miles+'s Avatar
From: In Diamond Bar, CA Brake Boosting like a Mother Focker!
The Si in a racing situation only gets trough 5 gears and 6th is for highway cruising/MPG's.
(Stock)
Old Jan 5, 2009 | 04:41 PM
07FG2's Avatar
I saw the video of bizzybear hitting the rev limiter in several gears, i got curious to wether if it was possible to hit the rev limiter in 5 and 6 because its not legal on the roads. I know that it might be possible in 5th and a i got a little curious about 6th, wether it will hit the rev limiter and top out or top out before that
Old Jan 5, 2009 | 07:08 PM
ajpturbopittsburgh's Avatar
(Stock)
I'm gonna reply to a couple of people that replied to this thread.
1st: I don't understand why people say "Aaa, it's illegal to hit those speeds anyway on a public road" For the most part it seems like little racecar drivers are the only ones that drive four banger hondas. Proof is all the civics with fart pipes on their cars including mine. I see old CRX's and civics with wheels and exhausts trying to race people all the time. So yes people take their cars to 130 mph all the time. So to the guy that said why do you car must be a wuss....What do you mean why do you care?...Give the guy a break he wants to know how fast our cars go.
2nd: The guy that said in a racing situation you only get through 5 gears and 6th is for highway cruising? 5th and 6th are pretty tight to me. You lose a whole 1000rpms when you shift from 5th to 6th. Look at my chart below. 70mph at 3000rpms is not exactly cruising, as evidence of the poor 29mpg highway that are cars get. These are SI's...fuel economy was a little lower on the list my friend.
Tire Size 215/ -45/17
OR
Tire Diameter
(in inches)
OR
Revolutions Per Mile
Axle Ratio 4.765
Redline (RPM) 8000
First Gear 3.267
Second Gear 2.130
Third Gear 1.517
Fourth Gear 1.147
Fifth Gear 0.921
Sixth Gear 0.659
Pasted from <http://www.f-body.org/gears/left.htm>
RPM 1st Gear 2nd Gear 3rd Gear 4th Gear 5th Gear 6th Gear
500 2 4 5 7 8 12
600 3 4 6 8 10 14
700 3 5 7 9 12 16
800 4 6 8 11 13 19
900 4 6 9 12 15 21
1000 5 7 10 13 17 23
1100 5 8 11 15 18 26
1200 6 9 12 16 20 28
1300 6 9 13 17 22 30
1400 7 10 14 19 23 33
1500 7 11 15 20 25 35
1600 8 12 16 21 27 37
1700 8 12 17 23 28 40
1800 8 13 18 24 30 42
1900 9 14 19 25 32 44
2000 9 14 20 27 33 47
2100 10 15 21 28 35 49
2200 10 16 22 29 37 51
2300 11 17 23 31 38 54
2400 11 17 24 32 40 56
2500 12 18 25 34 42 58
2600 12 19 26 35 43 61
2700 13 19 27 36 45 63
2800 13 20 28 38 47 65
2900 14 21 29 39 48 68
3000 14 22 30 40 50 70
3100 15 22 31 42 52 72
3200 15 23 32 43 53 75
3300 16 24 33 44 55 77
3400 16 25 34 46 57 79
3500 16 25 35 47 58 82
3600 17 26 36 48 60 84
3700 17 27 37 50 62 86
3800 18 27 39 51 63 89
3900 18 28 40 52 65 91
4000 19 29 41 54 67 93
4100 19 30 42 55 68 96
4200 20 30 43 56 70 98
4300 20 31 44 58 72 100
4400 21 32 45 59 73 103
4500 21 32 46 60 75 105
4600 22 33 47 62 77 107
4700 22 34 48 63 78 110
4800 23 35 49 64 80 112
4900 23 35 50 66 82 114
5000 24 36 51 67 83 117
5100 24 37 52 68 85 119
5200 24 38 53 70 87 121
5300 25 38 54 71 88 124
5400 25 39 55 72 90 126
5500 26 40 56 74 92 128
5600 26 40 57 75 93 131
5700 27 41 58 76 95 133
5800 27 42 59 78 97 135
5900 28 43 60 79 98 138
6000 28 43 61 80 100 140
6100 29 44 62 82 102 142
6200 29 45 63 83 103 145
6300 30 45 64 84 105 147
6400 30 46 65 86 107 149
6500 31 47 66 87 108 152
6600 31 48 67 88 110 154
6700 32 48 68 90 112 156
6800 32 49 69 91 113 159
6900 32 50 70 92 115 161
7000 33 51 71 94 117 163
7100 33 51 72 95 118 166
7200 34 52 73 96 120 168
7300 34 53 74 98 122 170
7400 35 53 75 99 123 173
7500 35 54 76 101 125 175
7600 36 55 77 102 127 177
7700 36 56 78 103 129 180
7800 37 56 79 105 130 182
7900 37 57 80 106 132 184
8000 38 58 81 107 134 187
Old Jan 5, 2009 | 07:23 PM
100miles+'s Avatar
2nd: The guy that said in a racing situation you only get through 5 gears and 6th is for highway cruising? 5th and 6th are pretty tight to me. You lose a whole 1000rpms when you shift from 5th to 6th. Look at my chart below. 70mph at 3000rpms is not exactly cruising, as evidence of the poor 29mpg highway that are cars get. >>>>These are SI's...fuel economy was a little lower on the list my friend.<<<<<<
OR
Tire Diameter
(in inches)
OR
Axle Ratio 4.765
Redline (RPM) 8000
First Gear 3.267
Second Gear 2.130
Third Gear 1.517
Fourth Gear 1.147
Fifth Gear 0.921
Sixth Gear 0.659
500 2 4 5 7 8 12
600 3 4 6 8 10 14
700 3 5 7 9 12 16
800 4 6 8 11 13 19
900 4 6 9 12 15 21
No my "FRIEND" 6th gear is for MPG's and if you had any common sense you would realize it.
Cruise on the freeway at 65 not 70 and your still at 3k. Just because the gear dont go to 2k or the "Desired RPM Range" for better MPG's does not mean 6th gear is for racing. The reality is that in 6th gear your not really gonna go anywhere since you pretty much max in 5th gear.
Besides just because the car is an SI doesnt mean people dont car about MPG's. Just because its an SI doesnt mean that people dont want to get all the desired MPG's out of the car.
I bought a MS3 which gets crap MPG's but that doesnt mean im gonna take off like a bat out of hell every light and floor every gear to lower my already bad MPG's.
:edit: Yes driving at 3k in this car is considered cruising. K Thanks Bye
Old Jan 5, 2009 | 07:36 PM
FijiBlueFG2's Avatar
Road House
I love the people that claim they can cruise around at 1200rpms
Old Jan 5, 2009 | 10:13 PM
Little_Nolan's Avatar
I believe that if the car sat at say 4200 at 70mph like a Type R or similarly gear car it would actually get better gas mileage than at 3000 at 70mph. You would require less throttle input with the higher RPM to reach your desired speed/change therefor reducing the amount of gas your car consumed.
Just a thought... I may be wrong though?
Old Jan 5, 2009 | 10:28 PM
nvynuke18's Avatar
cruising implies you are already at the desired speed, hence "cruising altitude" in a plane, so you wouldnt be changing very much any way. unless you want to pass quickly, in which case you should downshift. also how would a 40% higher RPM increase gas milage? wouldn't that just use 40% more fuel?
Old Jan 6, 2009 | 03:32 PM
forcefanajd's Avatar
the si is not speed limited....i have personally had my car to 157mph racing a c5 vette.
2008fijibluesi's Avatar
OP:
It has been said already but I want to clarify, because some false and confusing information has been posted;
The following refers to a stock Si:
You can hit the rev limiter in 5th gear, but you cannot high the rev limiter in 6th gear. Gearing and/or top speed governor do not allow the car to accelerate into the higher rpm range of 6th gear, which is a highway (or overdrive) gear, intended for use on the highway to achieve optimal MPG. This is a fact and cannot be disputed, either by charts of what the car could potentially do, or by someone else's "personal experience".
Anyone who drives sensibly on a decently long (50 miles or more) highway trip, will achieve better than 29 mpg. I regularly get 34 mpg on 200 mile trips (100 miles each way) to and from my GF's college, and that is with a few highway runs here and there.
***My car (2008 Si) has a top speed limiter of 133-134 mph, depending on how my car feels at the time. I've read, but never personally experienced that 2006 SIs did not have a top speed limiter, but were only limited by the gearing of the transmission. I've also read that Vtec will not activate in 6th gear (and that would make sense since it does not need it), but again, I've never personally experienced that, as my car limits my speed well below 5800.**
Old Jan 6, 2009 | 03:33 PM
Do you have an '06?
A few possibilities:
1)It wasn't even a "race", because an Si cannot keep up with a C5.
2)Your car isn't stock.
3)You're full of doo doo
Old Jan 6, 2009 | 03:59 PM
Kidnkorner's Avatar
Considering peak torque is so HIGH in the RPM range cruising at a lower RPM may be detrimental to fuel economy because you are lugging the engine thus requiring more tps angle.
What a whopper!
What model year is your vehicle? Some very early production 07 Si sedans weren't speed limited because I had one of the 1st few 07 Si Sedans to roll off the assemply line.
To be able to do 157 you must have had forced induction, nitrous or been driving down an 8% grade with 70mph wind behind you.
Old Jan 6, 2009 | 04:02 PM
ironworker's Avatar
ohhh really lets see a video or sumthin myne is a 07 all i can go upto is 134
Old Jan 6, 2009 | 04:03 PM
ZygSpeed's Avatar
... or a Hondata reflash?
Old Jan 6, 2009 | 04:05 PM
Kidnkorner's Avatar
Sorry Hondata reflash doesnt eliminate the speed limiter.
Old Jan 6, 2009 | 04:41 PM
Originally Posted by 2008fijibluesi
OP:
Go ahead and set your cruise control in Pittsburgh and in mountainous areas and you will not get your 34 mpg's. Sure go on the flat roads and you might get 40.
Also my car hits vtec in 6th gear and I'm not sure it's because of the Hondata reflash, but I cannot confirm it didn't before since I turboed the car early and don't remember.
And what do you mean it doesn't need vtec in 6th gear? If I'm going fast in 6th gear, 100mph plus and I want to go even faster with out shifting.....Then I guess I need it...speak for yourself!
Old Jan 6, 2009 | 05:00 PM
Kidnkorner's Avatar
Wow dude are you that inept at reading? Of course it's because you have the reflash the crossover point is significantly lower than stock.
You can hit the rev limiter in 5th gear, but you cannot hit the rev limiter in 6th gear.
Your Hondata Reflashed car isn't stock, douche
Old Jan 6, 2009 | 05:15 PM
Yeah no **** the crossover point is lower.
Are you sure of your info? So let me get this right. A hondata reflash doesn't eliminate the top speed limiter, but it allows the car to engage vtec in 6th gear which is otherwise not possible on a stock car. Why would they change one and not the other? I'm not sure
Old Jan 6, 2009 | 05:56 PM
jewjew bean's Avatar
1st... the final drive on these cars is crazy if you would put these engines in a 2300lb car it would probably go 12's. lol
2nd... on the 6th gear issue. Honda can't make a gear that would let the car cruise at 2.5k at 70 because the power would suck. As car savy people.... we understand the benifit of having lower gears but the average consumer wouldn't know and it would probably be an area of complaint for most buyers.
Old Jan 7, 2009 | 11:09 AM
07FG2's Avatar
OP:
Wait, i'm a little confused about people saying there is and there isn't vtec in 6th gear, so is there or is there not vtec in 6th gear?
Old Jan 7, 2009 | 11:18 AM
franklinhid's Avatar
i personally hit 158. in my car.
i do own a hona
i do own a civic.
i do own a k seriousss.
but its all in my 94 sedan, running on hondata
158 at about 6500rpms in 6th with the rev limiter at 9k.
stopped at 158 cuz i was shitting bricks..
just felt like posting.lol
my .02 cents cant apply here with stock si's
lol
