Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
Innovate Motorsports Wideband In Stock Ready to ship
Old Jan 5, 2009 | 10:08 AM
bigvalleyperformance's Avatar
Banned
Default Innovate Motorsports Wideband In Stock Ready to ship
What's up Guys and Gals
We just stocked a bunch of innovate products.
Everything from Wide bands to Bung and plug kit's.
We have innovates product lineup in stock Ready to ship.
LM1 Wideband
The LM-1 is the industry's first and best complete wideband tuning system. A single self-contained unit combines a wideband air/fuel ratio sensor controller, a 6-channel data logger, and an easy-to-read backlit LCD display. This is the unit used by tuners, racers, and engine builders the world over.
Tuning an engine for maximum power previously required long trial-and-error sessions on a dynamometer. With the LM-1, precise AFR measurement allows the user to correctly adjust many variables- including carburetor jetting, fuel injection, turbo fuel curves, etc.- without long and expensive dyno sessions. The meter’s digital signal processing technology provides data on exactly how rich or lean an engine is running at any load. The LM-1’s self-calibrating circuitry also compensates for changes in temperature, altitude, and sensor condition.
* World's only fully-digital wideband controller.
* Up to 6 Channels of data logging.
* Portable/ Handheld.
* Display both A/F and Lambda readings in real-time.
* Auto calibration to compensate for changes in temperature, altitude, and sensor condition.
* Two user configurable analog outputs.
* LogWorks - award winning tuning software.
The instrument can sample and store 6 channels of data- air-fuel-ratio and up to 5 other sensor data channels- internally in operation for later analysis on a personal computer. At a sampling rate of 12 samples/second the instrument can store up to 44 minutes worth of data in non-volatile memory. The data can be downloaded to a personal computer using a standard serial port and viewed/analyzed by the included LogWorks software or any standard spreadsheet program:
The LM-1 also features two analog outputs to connect to analog gauges, dyno computers, ECUs, piggyback controllers, and other devices with analog inputs. Analog output 1 comes setup from the factory ready for narrowband simulation; analog output 2 is configured as 1 volt = 10 AFR (.6 lambda) and 2 volts = 20 AFR (1.3 lambda). With the provided LM Programmer software these analog outputs may also be configured by the user.
Includes: LM1, Bosch 5-wire Wideband 02 Sensor, Analog Output Cable, 10ft. Sensor Cable, 10ft. Power Cable (Cig), 6ft. Serial Cable for PC Connection, Bung/Plug Kit, Software CD, and Quick Start Guide.
Innovate LM2
We love the value of this wideband setup! For nearly the price of a plain old wideband system, you get a full OBD-II aware data logger, code scanner, and display system. The LM-2 plugs into your OBD-II port, so it can read, display, and log any of the information your ECU knows. Plus, it's a wideband air/fuel meter. Plus, it logs it all to an SD memory card, so you can upload the results to your PC for analysis.
It reads and clears "Check Engine" codes. It has four programmable analog data inputs, if you should want to log even more information. It also has two configurable analog OUTPUTS, so you can feed data to gauges, shift lights, or anything else. It's got Innovate's own MTS serial data stream in/out connections, too, so you can share data among any other Innovate digital devices.
Kit includes the LM-2 control unit, Bosch 5-wire Wideband 02 Sensor, analog output cable, 10ft. Sensor Cable, bung/plug kit, software CD, and quick start guide. Plus, you get an awesome foam-padded carry case!
Now in stock.
Innovate XD-16
The Innovate "Standalone Gauge Kit" comes complete with the patented award-winning LC-1 Wideband Controller, NEW! XD-16 (16 in 1) 52mm Programmable Digital Gauge, Bosch 5-wire Wideband 02 Sensor, Bung/Plug Kit, Software CD, and quick start guide.
The Innovate XD-16 dash-mountable Digital Display ships as an AFR gauge, but can also be configured to display any channel of the Modular Tuning System. Key features:
-2 Bezels + 8 faces = 16 combinations (see below)
-3/4" thick, so it's possible to mount even in surface mount configurations
-3-character LED display
-Record/Calibrate/Peak Hold button
-Programmable (values and colors) digital needle
-Billet Aluminum bezel
The kit also includes:
-Male 2.5 to 2.5 cable to connect XD-16 to an LC-1, AuxBox, LM-1, ST-12, or DL-32
-Terminator Plug
-Mounting Hardware Kit
-Cable to connect to a PC for real-time logging and programming.
Innovate LC1
The LC-1 Kit contains everything you need to replace one of your pre-cat O2 sensors with a wide band sensor. The LC-1 has an output to convince the PCM that the original sensor is still there, an output to connect to your FlashScan and if you want, a place to hook up an Innovate XC-1 Air Fuel gauge. It's the lowest priced solution we know of for accurately monitoring your Air/Fuel ratio in real time.
Innovate DB gauge with LC1 wideband and Sensor
In partnership with Nordskog Instruments, Innovate Motorsports is releasing two new 52mm (2 1/16) air fuel gauges. Each gauge features a bright LED (available in blue or red), and retails for $289. Each kit includes the gauge, an LC-1 wideband controller, oxygen sensor and bung/plug, and the award-winning LogWorks engine-tuning software.
Key benefits of the DB kits include:
# The industry's most accurate and fastest-responding wideband controller.
# One additional available analog output (one connects to the gauge).
# Easy set up and wiring (instructions included).
# LC-1 incIudes Innovate serial in/out for adding additional modular tuning system (MTS) components. (Gauge itself is analog only- no serial)
# Blackout appearance when unpowered.
# Log directly from the LC-1 digital output into laptop w/included software
If there is anything you need we Stock the complete Innovate lineup.
DualCamDan
Southeast (Sales)
Dec 14, 2010 09:14 AM
b18bturbo
Mar 3, 2006 05:02 AM
K24 Turbo EF
Jun 13, 2005 01:52 PM
TWoody
Mar 17, 2005 11:14 AM
EGJDM
Aug 21, 2004 10:53 PM
