99' Accord Lighting Troubles
Old Jan 4, 2009 | 07:11 PM
darkchaos's Avatar
Default 99' Accord Lighting Troubles
I have this problem with my 99' Honda Accord and i was wondering if any one can fix it. For some reason when i put my gear shift to D4 and then look at my dashboard it's suppose to lit up right? But for some reason it doesn't light up but all the other light up like the park,reverse, D3,2,1 but only the D4 doesnt light up. Can anyone help me fix this problem? This is the first time that this happened. Thanks
Old Jan 4, 2009 | 07:16 PM
AccordInTheMaking's Avatar
Default Re: 99' Accord Lighting Troubles
Most likely the light bulb for the D4 symbol went out. You will need to take out the instrument cluster to be sure. Since you drive in D4 most of the time, its not surprising that this bulb went out before all the others. Get a service manual at your local parts store if your unsure on how to get the instrument cluster out. A blown out bulb will have a dark silver look to it.
twobit
Apr 24, 2005 06:43 PM
ondenoantra
Apr 28, 2004 06:55 PM
georgeda
Feb 6, 2004 04:51 PM
Spazoli
Jan 23, 2002 11:46 AM
