Cleaning out the garage - CRX stuff for sale MN
Old Jan 4, 2009 | 02:53 PM
TheShocker's Avatar
Default Cleaning out the garage - CRX stuff for sale MN
MAKE ME OFFERS!!
Making room in the garage... Buy my stuff! If you see something you want but the price turns you away, please make me a *reasonable* offer via PM. Almost all this stuff is for 88-91 Civic/CRX (unless otherwise noted). Plenty of vouches for me on H-T. Add shipping $ if you're not local (Twin Cities Metro).
$100 - C&R custom 2-pass aluminum radiator - 89 crx - b-series inlet/outlet
$60 - p06 ecu
$40 - pm6 ecu - sold
$50 -2000 vw passat intercooler - 2" in/out, tube and fin, small dent, no leaks - i can measure the core for interested parties...forgot to do this earlier.
$35 - half size 5G Civic radiator
$50 - crx headlights
$35 engine stand (not pictured, can photograph if interested)
$35 - tial 35mm wastegate lid and blue spring (.6 Bar, 8.7 PSI I THINK - buyer responsible for verifying this as I have not tested this spring in my car)
$35 - d16y7 (?) distributor
$25 - d16a6 distributor - sold
$20 - 89 crx mudflaps
$40 - 89 crx center vent WITH clock
$35 - Rear lower tie bar - 88-91 Civic CRX
$25 - 88-91 Si intake manifold with fuel rail and throttle body (no tps)
$35 - MOOG inner tie rod and misc steering rack parts 89 crx si
$15 - suspension techniques shifter bushing in box with instructions and lube (shifter end only, transmission bushing gone)
$20 - 96 GSR wheel center caps x2 - these are the 6-spoke wheels with the "hole" in the end of each spoke
$20 - 89 crx spare tire
$5 - golden eagle oil adapter AN fittings
$15 - oem 89 crx fuel pump - working
$10 - shiftlight
$10 - random foglights
$5 - GM 3-bar MAP pigtail
$15 - d16a6 valve cover
$25 - MSD ignition - never used or tested
$20 - 89 crx starter
$5 - timing cover (?)
$15 each - crx dipstick x2
$5 - crx front engine mount x2
$5 - crx trans mount
$5 - crx int. mani support
$10 - oil feed and drain gasket - garrett t3
$make offer - coolant cross pipe- 89 crx
PICS:
Old Jan 11, 2009 | 10:28 AM
TheShocker's Avatar
Default Re: Cleaning out the garage - CRX stuff for sale MN
up it goes. make offers on the pricing
Old Jan 29, 2009 | 10:27 AM
edlocke's Avatar
PM'd
Old Feb 14, 2009 | 09:44 AM
TheShocker's Avatar
PM6 ECU and d16a6 dist. are sold
REDBARON
Texas -OK -LA (Sales)
Feb 20, 2012 11:12 AM
zcrxt
Dec 4, 2004 08:42 AM
efracer
Apr 16, 2003 10:51 AM
TheShocker
Sep 1, 2002 04:25 PM
177ik3
Nov 28, 2001 06:57 PM
