Bolts connecting stock shock to the control arm...
Old Aug 5, 2002 | 10:57 AM
VTECorona's Avatar
Default Bolts connecting stock shock to the control arm...
My new suspension came in today and I can't get the bolts off of the stock shock. I sprayed it with Liquid Wrench and WD40 a few times and no luck. I even cracked a Snap-On 14mm socket trying to take it off. Am I better off going to a shop to have the loosen the bolt or is there a trick to it?
, two beers and a martini for whoever has an idea for me.
Old Aug 5, 2002 | 11:12 AM
LTB420's Avatar
Default Re: Bolts connecting stock shock to the control arm... (97RedTegGSR)
when trying to break the bolt loose don't use constant force to break the bolt loose try to use a quick set of jerks to get it loose.
Old Aug 5, 2002 | 12:11 PM
fatoldman7's Avatar
New User
A very common problem, if an impact wrench can't break it loose, you have to drill them out.
Old Aug 5, 2002 | 12:41 PM
VTECorona's Avatar
Default Re: Bolts connecting stock shock to the control arm... (fatoldman7)
I was thinking of bringing it to acura to see if they'd loosen them up for me but I know they would probably charge 50+.
Old Aug 5, 2002 | 12:44 PM
Mikey3000's Avatar
that bolt is prolly gonna break. happens all the friggin time and it sucks big time. you'll prolly have to get another control arm.
Old Aug 5, 2002 | 05:40 PM
jweller's Avatar
Default Re: Bolts connecting stock shock to the control arm... (Salvatore Leone)
PB blaster and an impact wrench took mine off nooooo problem
BTW-the pb blaster stuff is Far superior to WD-40 for rusted nuts
Old Aug 5, 2002 | 06:17 PM
KS-R's Avatar
Yup.. that happenned to mine.. on BOTH sides.. actually 4 of them were seized.. The ones from the lower control arm going to the subframe.. and the ones going to the trailing arm.. They're usually seized/rusted inside the bushings sleeve... I ended up using a cut off wheel and cutting the bolts off.. So.. gonna have to get replacements..
tooters bmx
Oct 6, 2017 11:01 AM
Civic Racer X 7
23
Aug 30, 2014 04:11 AM
88LsRex
May 11, 2011 08:13 AM
subgeniusdude
Nov 15, 2009 08:02 AM
M@
May 17, 2005 04:35 PM
