Headlight Wire
Old Jan 4, 2009 | 10:54 AM
pimmolloybom's Avatar
Icon6 Headlight Wire
I have a 97 Honda Accord. I need to splice a section of the headlight wire, but I have no idea what gauge of wire I should use. Any help would be much appreciated.
Old Jan 4, 2009 | 07:38 PM
AccordInTheMaking's Avatar
Default Re: Headlight Wire
That depends on what you are trying to drive from the headlight circuit. However, if its anything that takes more than an amp or two, then you should use the headlight voltage to turn on a relay, and use the relay to control what your using- otherwise you will end up blowing the fuse that controls the headlights. I think most headlight circuit wires are about 18 guage if your looking for a match, however I would still recommend hooking up a relay (DONT just use the stock wiring and install a bigger fuse!).
For reference here is a chart for wire sizes and maximum amperages:
johnp88gt
Jan 10, 2011 06:49 PM
sageuvagony
Oct 4, 2008 09:07 PM
Brycen
Oct 29, 2006 02:05 PM
B18EG6
Mar 20, 2002 09:29 PM
2005 TSX
Aug 2, 2001 09:09 PM
