More Tranny Questions
Old Jan 4, 2009 | 10:37 AM
HondaBryan43's Avatar
Default More Tranny Questions
Well i have an EF Hatch with a built Mini Me Swap and i have the DX 4 speed tranny. Well i want to upgrade to the 5 speed adn im not sure what exactly i need. Do i need to do new axles? New spindles? Please just let me know what i need to upgrade. Thank You
Old Jan 4, 2009 | 11:46 AM
Si-Samuri's Avatar
Default Re: More Tranny Questions
It depends on what year your car is and what spindles you are using. Please post so we can better help you.
Old Jan 4, 2009 | 01:21 PM
zCivic's Avatar
If your just changing your transmission you reuse your hubs(spindles) and axles. If you goto a B-series or 5 sp axles (other then HF) you will need to change your hubs but other then that your fine.
Old Jan 4, 2009 | 04:33 PM
Well to be have you guys help me. I have a 89 DX Hatch with the stock 4 speed transmission. So im pretty sure i have the stock hubs and all right now. So all i want is a 5 speed tranny soo i can have my longer gears and all. So what tranny should i go with so i dont have to worry about changing the hubs and axles? Could i build my 4 speed internally? Whats the best way to go?
Old Jan 4, 2009 | 04:53 PM
xci_ed6's Avatar
Dx or Si, 89-91
Get a new clutch at the same time.
Old Jan 5, 2009 | 05:24 AM
zCivic's Avatar
I have yet to check the internals of the 4sp so I can't verify if can/cant just get the gear sets and swap them. Just reuse your parts and get a new/different transmission. Replace clutch if needed (prob is old and needs one any ways)
Old Jan 5, 2009 | 05:47 AM
Well i just want a Cable 5 Speed Transmission. I have a 90 DX Hatchback. It has the stock 4 Speed Tranny. What tranny should i go with? Does anyone know where i can get a nice one at? Do i need new shift linkage? New brackets? Sensors?
Old Jan 5, 2009 | 06:36 AM
xci_ed6's Avatar
Swapping internals is a retarded idea. Get the correct transmission. You would need the other tranny to get the parts, and I doubt it would work anyway.
Old Jan 5, 2009 | 02:16 PM
sgallagher's Avatar
Dx is 5spd. You have a std model(or at least a std trans).
Get an si trans(89-91), axles and clutch. Shift linkage is the same, cable is the same.
scottso990
Nov 3, 2010 07:22 AM
90 civic hb
Jul 22, 2007 06:01 PM
FernEF
Oct 18, 2006 05:42 AM
89 CRX SI
13
Apr 22, 2002 09:21 PM
zcivicz
30
Apr 15, 2002 02:29 PM
