FS: B Series Garage Sale
PM me here. Thanks for looking.
Shipping not included
Local Pickup on Blocks, Cars, and Trans
Pictures available on Request
Parts are for B Series unless noted
Many Other OEM B Series Parts Available
Distributor OBD1 ZC TD-43u New $100
Distributor OBD2 B16 Used $120
Distributor OBD2 GSR for External Coil* $100
Spark Plug Wire Set B16/GSR MSD Black New $100
Distributor Cap and Rotor B16 MSD New $50
Distributor Rotor MSD New $20
Pistons Weisco 9:1 Comp 81mm Bore B Series New $400
Pistons Weisco 9:1 Comp 81.5mm Bore B Series New* $400
Pistons Nippon 10:1 Comp 81.5mm Bore B Series New $150
Rods B16 Scat Used 1 Month $200
Block B16 Stock Used Complete $250
Block B16 Stock Needs Rings* $300
Block B18 LS Integra (No Crank) Used $50
Crank B16 Good Condition Used $50
Crank GSR Good Condition Used* $50
Intake Manifold Inline Pro Used* $500
With Fuel Rail and RPM Throttle Body RC injectors
Intake Manifold GSR Custom* $150
Intake Manifold GSR Gude Ported Used* $50
Intake Manifold OEM B16 Used $50
Intake Manifold Skunk 2 B16 Used $150
Intake Manifold Venom Polished B16 Used $100
Intake Manifold Gasket B16 Hondata Used $25
Intake Manifold Gasket B18 LS Hondata New $50
Injectors RC 1000cc Hi Impedance 4 Used 1 Month $350
Injectors RC 550cc Low Impedance 4 Used* $280
Injectors DSM 450cc Blue Used Set of 4 $50
Head B16 Rebuilt Fresh Great Condition Clean Used $700
New Valve Seals
SuperTech Valve Springs and retainers
3 Angle Valve Job
Mild Porting
Head B18 LS (2000) Integra Used $70
Head B18 LS (1994) Integra Used $50
Head GSR with Cams Used Good Condition* $500
Head GSR Gude Ported Good Condition Used* $500
Head B16 Stock with Cams Used * $500
Head Gasket OEM 81mm Bore B16 NEW $100
Valve Cover Red K Series New in bag Type R* $200
Valve Covers B Series Used Qty 6 $50ea
Timing Belt OEM B16 NEW $100
Head Studs Golden Eagle B16 Used $100
Head Studs ARP GSR Used $75
Main Studs B16 Golden Eagle NEW $80
Oil Pump B16 KMS/OEM Used $50
Water Pump B16 OEM Used $30
Cams Gude All Motor Regrinds* Used $100
Cams GSR Used $100
Cam Gears Skunk 2 (Blue) Used $175
Cam Gears Skunk 2 (Titanium) New $250
Cam Gears STR Used * $80
Cam Gears AEM Red Used* $80
Cam Gears AEM Blue Used* $80
Flywheel XTD Aluminum Used* $50
Flywheel Clutch Masters Used* $100
Flywheel ACT Streetlight Used Good Condition $150
Clutch ACT 6 Puck Sprung Used Fair Condition $50
Clutch ACT Street Disk Used Good Condition $75
Clutch ACT Heavy Duty Pressure Plate Used Good $100
Clutch ACT Extreme Duty Pressure Plate Used Good $100
Clutch disk, Flywheel, Pressure plate ACT Set Used* $200
Turbo Manifold and 3” Downpipe AFI
Vband Wastegate Top Mount T3 B Series New $600
Wastegate Tial 38mm V Band New $250
Final Drive 4.7 Prodrive B16 Used Great Condition* $120
Spool Prodrive Used Great condition* $190
Scatter Shield Gold Used* $50
Quaife Sycro Mesh Gear Set Complete* $2000
Needs new Syncros Gears are fine Used
Trans Hydro GSR (1994) $600
w Phantom Grip LSD Good Condition Used
Trans Hydro Type R (1998)* $1000
Great Condition Purchased New from Dealer
Low Miles
Trans Hydro D16y8 5 Speed Good Used* $150
Trans Auto LS Integra 2000 Good Used* $100
Axles Drive Shaft Shop Stage 1 Used on all motor Car* $250
Axles Stock B16 Axles $100
Sway Bar Front Type R $25
Sway Bar Front GSR $25
Sway Bar Rear GSR $25
Strut Bar for EK* $50
Wheels 17” Axis Mag Lites Sliver 4 with $800
2 BFG GForce TA Drag Radials 225/45
2 Kumhos 215/45
Wheels Bogart Flystar Front and Back Used* $1000
With Slicks and Tires
Wheels Bogart Gold stars 5 lug 2 front only Used* $600
Wheels Type R Wheels with Slicks 2 Used* $300
Wheels Prelude 2 Wheels Need Tires* $50
Tires BFG Drag Radials Used* $100
97 Civic Hatch $3000
New Silver Paint
2000 SI Front End (New Lights, Hood, Fenders, Bumpers)
GSR Rear Disk Conversion
GSR Front Brakes
GSR Leather Seats Front and Back
New Black Carpet
Stock GSR Suspension
Carbon Fiber Rear Hatch
OBD1 Conversion
Engine Harness
Walbro 255 High Flow/ High Volume pump
Pillar 3 Gauge Pod
2000 SI Gauge Cluster
No Engine
Steely Wheels New Tires
B Series Shift Linkage
B Series Mounts
Thermal 3” Exhaust
Many Extra Interior parts
Very Clean Car
83 Honda Civic 2 door Blue 5 Speed Does Not Run $50
New Valve Seals
3 Angle Valve Job
Mild Porting
Cams GSR Used $100
Low Miles
2 Kumhos 215/45
New Silver Paint
GSR Front Brakes
New Black Carpet
OBD1 Conversion
Engine Harness
Pillar 3 Gauge Pod
No Engine
B Series Mounts
Thermal 3” Exhaust
Very Clean Car
450cc what kind of setup would they be ideal for? im still learning. Looking for obd2a injectors for a stock b16a2. the Higher the number for ex. 450cc, the more fule they provide??
sill waiting on the pics of the venom b16 intake manifold sent to Bigdadymark06@aol.com. thanks
