1997 Honda Accord SE Diagnostic Connection Location???
Old Jan 4, 2009 | 08:20 AM
Rykertest's Avatar
Default 1997 Honda Accord SE Diagnostic Connection Location???
I looked on the FAQ and I know of the diagnostics connection behind the ash tray. However I've been told (incorrectly I suspect) that's not the one I need to find a CEL code. Is there another connection somewhere I don't know about or is that the one I use the scan tool on to get the code? Thank you in advance.
Old Jan 4, 2009 | 09:02 AM
P_Adams's Avatar
Default Re: 1997 Honda Accord SE Diagnostic Connection Location???
At the intersection of the dash panel and the right side kick panel.
http://alflash.com.ua/OBDII/Hondaloc.pdf
P
Old Jan 4, 2009 | 09:29 AM
Rykertest's Avatar
P
Thanks for the quick reply. So letter C then on your image?
Old Jan 4, 2009 | 09:52 AM
TheMuffinMan's Avatar
He knows where you live!
It would be closer to A
Old Jan 4, 2009 | 10:05 AM
Rykertest's Avatar
thanks!
Old Jan 4, 2009 | 10:08 AM
P_Adams's Avatar
It's a little confusing....
For the two contact quick diagnostic plug:
over by the right side door end of the dash.
A on the Acura diagram
B on the Honda diagram
P
Old Jan 4, 2009 | 12:49 PM
Rykertest's Avatar
So is the cord I'm looking for being held in place in a light blue clip right under the corner of the dash/glovebox? If thats not it there is nothing over in that area that could be it. Thanks again.
Old Jan 4, 2009 | 01:02 PM
It's that blue connector there.
Take it out of the plug and then stick a paper clip in it.
Old Jan 4, 2009 | 01:31 PM
Rykertest's Avatar
OK, I feel like a moron here. Why would I stick a paperclip in it? Isn't this the cord I attach the scan tool too to get my code?
I'm headed over to autozone tomorrow morning to get the reading for my CEL.
Sorry for the noob questions. Thanks again.
Old Jan 4, 2009 | 02:19 PM
P_Adams's Avatar
There are two connectors.
The Multipack Connector to which a Scan Tool would be attached is behind the Ashtray on your car.
The Blue Connector to which you're being directed to is a diagnostic port which when jumped between the two connections will allow the ECM to flash a code thru the "Check Engine" lamp
P
JDM SLICK
Jun 20, 2009 12:01 PM
lsgfrs
Dec 12, 2008 05:46 PM
greg1111allen
Paint and Body
Feb 8, 2008 10:33 PM
BrabusCClass
Feb 7, 2007 05:46 PM
Setsuna F Seiei
Sep 16, 2004 04:21 PM
