WTB: eclipse/talon/lancer/mirage differentials or parts trans
looking for stock or used good/broken obx diffs, specifically the 8-bolt ring gear versions from:
89-99 Eclipse/Talon awd front diff
89-94 Eclipse/Talon 2wd turbo (4g63)
Lancer (non-evo)
Evo 1-3 front
Mirage
as far as the Eclipse awd front diff goes i'm told it doesnt matter what gen as all awd front diffs are the same, if this is incorrect somebody please lmk.
In any case I need at least one of these asap to verify fitment into a custom project. This is kind of a back burner project so the budget on this is tight, can't be dropping $$$ on a complete good trans, quaife, etc.
Just looking for a spare stock unit from a broken trans or after upgrading to an lsd, used obx after replacing, etc
will also consider a complete trans for parts if the price is right- cracked case, broken input shaft, etc
Anyone got anything? pm me
Lancer (non-evo)
Evo 1-3 front
Mirage
I need just the front differential assembly itself, no ring gear or anything else. I'm not sure if the Eclipse & GVR-4 diffs are exactly the same, I'll see what I can find out
