Exhaust Rattling Against Heat Shields What To Do?
Old Aug 5, 2002 | 10:07 AM
Chris_R's Avatar
Default Exhaust Rattling Against Heat Shields What To Do?
My exhaust is rattling by vibrating up against the heat shield around the resinator. how can I stop this? The heat shields are not loose anywhere, and I cant bend them any further back, so is there a way to just "tighten" up the exhaust itself?
Thanks!
Old Aug 5, 2002 | 10:10 AM
Johnny Tran's Avatar
Default Re: Exhaust Rattling Against Heat Shields What To Do? (OutkastLV)
remove them......
Old Aug 5, 2002 | 10:14 AM
ITR764's Avatar
Default Re: Exhaust Rattling Against Heat Shields What To Do? (Johnny Tran)
remove them......
yeap
CPR's Avatar
CPR
Default Re: Exhaust Rattling Against Heat Shields What To Do? (ITR764)
or trim them
Old Aug 5, 2002 | 11:04 AM
Chris_R's Avatar
Default Re: Exhaust Rattling Against Heat Shields What To Do? (CPR)
Its funny how I figured out that was the problem. I thought it was rattling from inside the resinator itself, so I tried something crazy. I wedged a couple of potholders into a couple of spots where the exhaust was closest to the heat shields, and Wal-la no more rattle.
So am I to assume that removing them will not cause any heat problems?
Old Aug 5, 2002 | 11:05 AM
AllMotorITR's Avatar
New User
I would trim them instead of removing them. They are there for a reason.
Old Aug 5, 2002 | 11:11 AM
Chris_R's Avatar
Default Re: Exhaust Rattling Against Heat Shields What To Do? (1 FAST R)
Thats what I was thinking.
Old Aug 5, 2002 | 11:18 AM
Asahi's Avatar
just remove them.
no issues with mine without them
Old Aug 5, 2002 | 11:19 AM
MPH's Avatar
MPH
New User
Default Re: Exhaust Rattling Against Heat Shields What To Do? (Asahi)
Tin snips are your friend
Old Aug 5, 2002 | 11:28 AM
uNF$@#!'s Avatar
Default Re: Exhaust Rattling Against Heat Shields What To Do? (MPH)
ok, i dont know how the heck you do it...
basically i loosened the 2 rubber hangers for the exhaust bpipe area and then tried to remove the heatshield... (for another project). impossible to remove!
anyhow the project is done, but im just curious to what the heck did i do wrong
Old Aug 5, 2002 | 11:31 AM
EagleR's Avatar
Default Re: Exhaust Rattling Against Heat Shields What To Do? (Soup ****)
Just cut the SOB off of there....
Old Aug 5, 2002 | 11:39 AM
disordeR's Avatar
Default Re: Exhaust Rattling Against Heat Shields What To Do? (EagleR)
bend them
Old Aug 5, 2002 | 12:23 PM
B2FiNiTY's Avatar
Default Re: Exhaust Rattling Against Heat Shields What To Do? (disordeR)
Bend, cut, or remove which ever way is the best to you. I just removed all of them.
Old Aug 5, 2002 | 12:51 PM
Dave-ROR's Avatar
took me a solid couple of minutes to drop the exhaust, then a few more to remove the heat shields then 30 seconds to move the exhaust from under the car..
end result: ITR-NC/FL giving you the finger when you pass them at 8000rpm.. priceless (although at that time I did have a straight pipe on the car.. lol)
Old Aug 5, 2002 | 01:20 PM
Chris_R's Avatar
Default Re: Exhaust Rattling Against Heat Shields What To Do? (SoFreshAndSoCleanClean)
Well, I guess I'll try to get them off as much as possible. Cutting or whatever. Seems like thats the easiest way to go.
Old Aug 5, 2002 | 01:51 PM
disordeR's Avatar
Default Re: Exhaust Rattling Against Heat Shields What To Do? (B2FiNiTY)
ahh so you removed all of them then...
mine still rattles.. grr
Old Aug 5, 2002 | 01:57 PM
01PYITR's Avatar
Warrenty is a freind, covered under warrenty for me.
Old Aug 5, 2002 | 02:57 PM
underrated99si's Avatar
bend them with a hammer to minimize rattle
Old Aug 5, 2002 | 03:22 PM
nsxtcjr's Avatar
New User
Default Re: Exhaust Rattling Against Heat Shields What To Do? (underrated99si)
If you do remove them, don't park your car over any tall grass.
Unless you want to burn it down...
Old Aug 5, 2002 | 04:24 PM
B16CRX's Avatar
Default Re: Exhaust Rattling Against Heat Shields What To Do? (nsxtcjr)
Will removing them have any adverse affects on the interior of car? I tried the bending last week on my friends 01, but it didn't help much. The reason I didn't remove them is because I figured Honda wouldn't put them there if they didn't do anything.
Old Aug 6, 2002 | 05:37 AM
Chris_R's Avatar
Default Re: Exhaust Rattling Against Heat Shields What To Do? (B16CRX)
Will removing them have any adverse affects on the interior of car? The reason I didn't remove them is because I figured Honda wouldn't put them there if they didn't do anything.
My thoughts exactly.
f22a1 ftw
Jun 9, 2011 07:07 PM
biggjerryc
May 25, 2008 12:02 PM
hometheaterman
Apr 10, 2005 08:05 PM
94ls
Nov 26, 2003 11:10 PM
