d16a1 pistons
anyone tell me if you have a 93 cx will 89 integra piston work as "pistons with reliefs" to do a mini-me swap. on the mini-me thread from BauleyCivic said to use a cx block you would need pistons with reliefs for 4 valves but also said if you use d16a1 pistons would raise the compression so i wanted to kno if the d16a1 pistons would be good for the cx block since i needed pistons anyway. Does anybody have any i could buy??????
