sent to state ref.......need to pass
Old Jan 3, 2009 | 05:22 PM
dc2619's Avatar
Default sent to state ref.......need to pass
i went to the test and didnt pass i need to fix
install-non vented fuel cap
check/repair high hc emissions
check/repair high NOx emissions
set timing/idle to factory specifications-reads appx.12 degrees BTDC.should be 16BTDC
what do i change or do to pass emissions i got a stock b18 with a edelbrock throotle body and skunk 2 intake manifold and toda cam gears
Old Jan 3, 2009 | 06:57 PM
sublimnal's Avatar
Default Re: sent to state ref.......need to pass
why were you sent to the state ref,
if its because you just have a modified car and they sent you there, you can just pay the tix and get it over with if you have problems passing the inspection
Old Jan 3, 2009 | 07:03 PM
EFsSuck's Avatar
move out of cali lol. R will be safer, and you can modify her without issues from "officials".
but to help. go to your dealer and get a new gas cap. and set your timing to 16*. hopefully that brings your HC/NOX to where they need to be.
Old Jan 3, 2009 | 11:35 PM
dc2619's Avatar
i got sent cuz my valve cover was cut and had a aem fuel pressure regulator and a loud exhaust.......and i cant drive my car intill i pass
Old Jan 3, 2009 | 11:58 PM
copsloveme's Avatar
you were given a list of **** to fix and you still ask what you need to pass emissions?
Old Jan 4, 2009 | 12:20 AM
dc2619's Avatar
it dosent say what i need to fix it just says i have a high NOx-hc
Old Jan 4, 2009 | 01:34 AM
sheekdude's Avatar
Just return you car to stock... If you dont know how, go to a performance/mechanic shop.
Old Jan 4, 2009 | 08:39 AM
ef8-dc2619's Avatar
seems pretty easy to return to stock if you still have your stock parts, but I thought sk2 mani was smog legal and as for the FPR and valve cover Take off and use a stock one.
GL bro
Old Jan 4, 2009 | 01:55 PM
dc2619's Avatar
i put all the stock parts back on but it didnt pass emissions ........i need to lower the hc and NOx emissions ......how do i lower them
Old Jan 5, 2009 | 01:05 AM
p28yaj's Avatar
Just put your car back to stock. Also get a new cat, spark plugs, o2 sensors, change oil, and make sure to clean your air filter or buy a new one. These are the things i did for my 97 gsr to pass.
Old Jan 5, 2009 | 10:48 AM
redsidriver's Avatar
i thought all state refs got laid off? i got a ticket last summer and had to just pay the ticket cuz i couldnt take it to state ref. they are just raping you.i dont think a fuel pressure regulator is illegal as long as u have it at stock fuel pressure. i have 2 valve covers one stock and another cut for when it needs to be tuned but i always roll with the stock one . call that state reff number first and see if they are even back to work .
Old Jan 5, 2009 | 09:35 PM
dc2619's Avatar
ya there back in buisness i went the first time and didnt pass i got to go again thurday and still got 2 more fix tickets to pay they get u for everything so watch out if ur in the chula vista area.......
Old Jan 7, 2009 | 02:58 AM
irev210's Avatar
buy a new fuel cap
buy new o2 sensors, spark plugs, spark plug wires, cap/rotor, put on stock exhaust manifold, buy a new catalytic converter
set the timing and idle to factory spec (not sure how you are confused by what that says)
Seriously, if you don't understand what mods do to your car in california, you probably shouldnt be making them.
Old Jan 7, 2009 | 12:40 PM
u should probally remove the cams and throttle body back to stock as well
langjairicer
May 28, 2010 01:13 AM
rotascircuit
Oct 10, 2009 09:28 AM
kevin96GSR
Apr 26, 2004 09:16 AM
blackitrspec
Apr 3, 2002 08:37 PM
