skunk2 pro vs tuner
Old Jan 3, 2009 | 03:40 PM
gsr96cx's Avatar
Default skunk2 pro vs tuner
What is the difference in performance between the two(tuner and pro series)?
Which one would work best with a setup like; gsr block with itr piston supertech dual valve spring with flat valves? ex. tuner stage2 vs pro stage1, tuner stage2 vs pro stage2
Sorry for the newbish question but i tried doing some research and for some reason ended up stuck.
Thanks for any help
Old Jan 3, 2009 | 04:44 PM
burningrex's Avatar
Default Re: skunk2 pro vs tuner
i assume you are talking about cams?
you will be better off going with the tuner stage2 the pro1 and pro2's and designed for higher compression motors or more built motors... pluse you'll most likely need different valve springs for the pro cams
i would try searching in the all motor sections... it has been done plenty of times before
99kleansi
Dec 19, 2009 08:10 AM
gsr96cx
12
Jan 10, 2009 11:37 AM
HondaGuy02
Sep 14, 2008 08:27 PM
vtec4max
Jul 28, 2007 08:49 PM
Drew17th
Nov 6, 2006 06:12 AM
