how do i get an exhaust system that is going to fit?
i am in the process of a b18c swap into my 93 civic hatchback and i am getting parts together so i have them for when i swap the engine in.
My main concern right now is my exhaust system, i already bought a megan header for the b18c and i dont know what to do from there, will i be able to bolt up an exhaust specifically for my car? Or wont that work since i have a header that is for an integra? I dont plan on running a cat so would it work to run a test pipe like the adjustable kind or what? i would really appreciate any help. Thanks in advance.
You can get an adjustable test pipe or just make your own or modify one. I put an exhaust for 94-99 GSR on my EJ1 with B16 swap because i had the exhaust laying around,, I just took a section out of the test pipe to shorten it to the correct length and welded it back together. I would think if you got a cat back system made for your car and an adjustable test pipe that should work.
93gsrcoupe
Apr 13, 2006 10:29 PM
