1993 honda accord
i just buy this car for few month, but a few day a go i notice that i have a major oil leak. it drip on the timing belt side . it drip crazy
people said it the seal leak
i wonder how to fix the problem? and how much the garage cost
1) Front Crankshaft Seal leak
2) Counterbalance Shaft Seal leak and
3) Oil Pressure Switch failure
I would suggest you check the oil Pressure switch first. It is the easiest to check, and the cheapest to fix. It's mounted just above the Oil Filter on the rear of the engine. It looks like this:
Either an open end wrench or a deep socket will get it off. I believe it's 22mm.
It takes about .5 hours Labor (at the shop's prevailing labor rate) + the part$ + tax.
Like I said, check that first, If that passes muster, then we'll discuss the other possibilities.
P
thank
but it not look like they leak on that side .
i ask some mechanic person they said it the front seal leak or crankshaft seal or some like that every time i turn the car one start leak like crazy
they said it cost around $650 to fix
If that price also includes the (supposed)
Contaminated Timing belt
Crankshaft Seal
Camshaft Seal & Retainer
and Waterpump
then he's within the expected cost range
P
