a/f below 13:1, your plugs look like?
I run now about 13:1 a/f ratio and the spark plugs are very black and very sooty.
I drove with 14:1 more than 8000 miles without any problems on 440cc, pistons look very good and spark plugs was a bit brown, like it should be.
Now with 720cc and about 13:1 af ratio my plugs are black.
perhaps your partial throttle tuning area is running rich. how did you check your plugs? did you make a hard pass and then shut the engine off completey then checked the plugs or did you drive around and then check the plugs?
