575 WHP s2000... STOCK BLOCK
stock block, stock head gasket,Cams, head studs, everything internal- UNTOUCHED.
Custom intake manifold and exhaust manifold designed and built by Ben.
Tuning was on MoTeC m800 by Ben
Custom Fuel injectors
twin wals in-tank.
26 psi, more boost coming soon- ran out of map sensor
twin wals in-tank.
690 is the record on stock piston rods.. do not know if he had head work or a head gasket.
this guys motor is 100% stock other than the ap2 oil jets
the motor will be fine, the drivetrain, well, not so much
it really just depends how aggressive he gets off the line. whatever happens just get it on tape!
The motor will easily outlast the rear end... hopefully you dont have slicks because you won't get more than 3 passes out of it. But that's just a perfect opportunity to upgrade it.
he just mounted 24.5 x 8s today.. car only weighs 2400 with him in it, hopefully it wont produce alot of weight/force when launching
Have you never seen drag guys run stocks blocks all year long? There's many b,h,f,k stock blocks above 500whp all day don't know why this would be any different. On pump might not last but on race gas should last all day.
There's a guy running 9.7s on a stock k20 block made multiple passes...
At this point, he doesn't seem to worry much if its going to blow up since other people have made 50-60 more hp and last.
awesome work
