test Pipe oil consumption
Yes id id a search.
Just curious how much you guys burn with a test pipe or gutted cat... I burn about 1.5 per change...which sucks...I use penzoil 10w-30 non synthetic
please post how much (if any) you burn and the oil you use
In alot of the cases i have seen someone put a test pipe on or gutted there cat oil consumption has always gone up...sometimes drastically. Mine is up a little more then i would like.. I changed my pcv valve and everything. i dunno.. i think my valveguides are fucked.
I'm trying to understand your thinking...
Well I definately run no cat and I see no drop in oil...
Mobil 1 10W-30
The use of a test pipe does promote extra oil consumption... plus the smell is awful.
Will
Maybe they just drive the car harder after? The two are not correlated...
they go hand in hand.............test pipe + track = more oil lost
recentely u use 4 quarts of 5w-50 Castrol Full syn oil after 25 laps in streets
of willow i lost one full quart of it, and i ran with a test pipe.
Back in July, i use 5 quarts of 5w-30 Mobile1 Full syn in Califonia Speed way
only 18 laps, only 3.5 quarts left, and this was with stock CAT, but it was a really
hot day tho in the second case i assume that i over fill with engine oil, so
i
, there are many consequences that may cause oil burnning
however , i think lots of VTEC kicks, lots of oil will burn, next time
i will try to measure my oil @2500miles with out going through a track event.
just keep in mind, and keep at least 3 quarts of oil in ur engine~!!!
i
, there are many consequences that may cause oil burnninghowever , i think lots of VTEC kicks, lots of oil will burn, next time
GOSHDARNIT!!!
I just tore down my ENTIRE motor and ordered new rings and pistons when
ALL I HAD TO DO WAS put the CAT BACK ON???
What a waste of time and money...
At least Ill be a clean burning race car..
i didnt know the test pipe mattered for burning oil . . .now if your kicking it in vtec alot then yes you will burn a bit of oil , that sounds like a bit much though.
Well, since you all bring it up, you have the burden of proof to show that a test pipe increases oil consumption.
Your rings do not know whether there is a cat installed downstream or not... and the above listed figures showing .25 quart difference in oil level aren't exactly scientific.
Yes id id a search.
all day, but right now, I just don't see it.
BlackCRX
Aug 29, 2002 01:02 PM
