Mpfi swap
Can you use a non si intake manifold with a si ecu?
Trying to do a mpfi swap but i dont know if the manifold came off a si or not,got it from a friend..
Will si harness clip fit into non si intake manifold?
So im going to go to the junk yard to pick up
si ecu
si disturbutor
so harness
some extra wires
is that the main parts i need?
si ecu
si disturbutor
so harness
some extra wires
Just get the whole/complete intake manifold off any multi-point motor if possible. makes it way easy...
theres hella info on this. just go to google and type in "MPFI Conversion" or DPFI to MPFI....
