b16 p28 question
Old Jan 2, 2009 | 09:23 AM
bakomack's Avatar
Default b16 p28 question
I have a 91 crx with a b16a2 all converted to obd1. obd1 injectors yada yada. only upgrades are clutch flywheel dc 4-1 header and aem intake. ls cable trans
im on a stock p28.
im curious. how much power am I actually not using running on a stock p28, obviously it needs to be chipped but i have no money right now.
how much power will I gain if I add hondata?
I have an s200 right now ( not installed ) but wanna upgrade to the s300. how much of a difference will that make?
Old Jan 2, 2009 | 10:08 AM
iwanttokillgod's Avatar
Default Re: b16 p28 question
thats bad the fuel maps and timing maps are way diff get the p28 chipped you dont have any mods that you need hondata
Old Jan 2, 2009 | 10:25 AM
bakomack's Avatar
I have a b16b with stage 3 brian crower cams, springs and retainers, port and polish, high flow fuel rail, 550 injectors, blox mani, adjustable cam gears, blox tb, and a few other things. the hondata is for this motor. im going to bar the b16a2 into the crx before I swap this motor in
Old Jan 2, 2009 | 02:12 PM
mouab18c1's Avatar
im on a stock p28.
this says that those stated above are the only upgrades..your last post says you're motor is built...i would not run the motor on the stock p28...it'll mess up your fuel system...so get it chipped before you even start it....
Old Jan 2, 2009 | 04:36 PM
for one you never stated that , two you will not pass the state ref with a p28 on a b16a2
bakomack
Jan 2, 2009 06:28 PM
Plugs
Jan 24, 2005 03:11 AM
is3oo
May 17, 2004 09:34 AM
cjohnson_2
Jan 19, 2004 11:58 AM
crx1856
Jun 15, 2003 09:37 PM
