car won't start
Old Jan 2, 2009 | 08:06 AM
nkhd's Avatar
Icon2 car won't start
I have replaced the head gasket and timing belts on my 92 accord LX.
The car will not start. I could not get a spark from the spark plug holding it against the motor. I have traced all the grounds and harness connections and cannot find any problem.
Is there a sensor that will cause it not to fire?
I guess what I am looking for is what to check and how to do so.
Thanks for any help.
Old Jan 2, 2009 | 07:26 PM
alkoholikwun's Avatar
Default Re: car won't start
getting any check engine lights.
defected dizzy? maybe
Old Jan 2, 2009 | 09:15 PM
casper.hughes's Avatar
make sure your t stat ground has good connection if you do have a check engine light then check for icm output i dont know the color of the wires but find a diagram and find the icm output voltage and input make sure that the icm is getting voltage from the pcm and then check for output voltage if there is voltage going in but not out then check all wires and if all wires are good i would recommend getting a icm.
Old Jan 4, 2009 | 10:28 AM
nkhd's Avatar
OK really dumb question -but i cannot find a diagram anywhere---on a 92 accord igniter i pulled off three wires the dark green, light green,and black and yellow. I think i put them back right but not sure. I swear i am getting alzheimers way early.
the yellow /green I did not remove
The next one i think is the light green
then the dark green
then the black/yellow goes on the side
Is this correct?
the readings mostly checked out but i need to borrow a real MMeter from work. I have two but they give different answers.
Old Jan 4, 2009 | 02:04 PM
kvkevin09's Avatar
i think is ;miss timing , you just blow the engine ,
it happen same my car
Old Jan 9, 2009 | 12:23 PM
nkhd's Avatar
changed coil still no spark
Old Jan 9, 2009 | 12:35 PM
nkhd's Avatar
I am getting a 15 error code. one long and five short blinks.
Old Jan 9, 2009 | 03:36 PM
nkhd's Avatar
the tach doesn't read while cranking
Old Jan 9, 2009 | 04:40 PM
nkhd's Avatar
the distributor has yellow powder in it - where would that come from?
Old Jan 9, 2009 | 04:49 PM
dtapia's Avatar
Here is the icm wiring diagram.
Old Jan 9, 2009 | 05:07 PM
nkhd's Avatar
thanks for the information
however the diagram doesn't match my car.
I have a 92 accord with a F22a4 engine
the igniter has yel/grn lt grn dk green black/yel
Old Jan 10, 2009 | 06:44 PM
nkhd's Avatar
got her running
thanks
bmxerforlife58
Oct 20, 2013 11:09 AM
Hey_T
Nov 14, 2009 08:58 AM
chuckmotz
Aug 16, 2005 07:59 PM
nacho
Jan 16, 2003 03:32 PM
